HP EliteBook 8470p Battery Replacement
    1. HP EliteBook 8470p Battery Replacement, Battery: step 1, image 1 of 1
      • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
      • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
      Ask FixBot
    2. HP EliteBook 8470p Battery Replacement: step 2, image 1 of 1
      • Slide the battery latch positioned to the right over to the right side. Hold it there.
      Ask FixBot
    3. HP EliteBook 8470p Battery Replacement: step 3, image 1 of 1
      • With the latch opened, pull the battery out of its socket firmly.
      • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
      Ask FixBot
2 other people completed this guide.
Owen Bangs
798 Reputation
5 Guides authored
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 5-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G3
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 107
All Time: 2,190
