HP EliteBook 845 G9 Audio Jack Replacement
    1. HP EliteBook 845 G9 Audio Jack Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 845 G9 Audio Jack Replacement, Before you begin: step 1, image 2 of 2
      • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
      • Save your work, fully shut down your laptop, and unplug all cables.
      Ask FixBot
    1. HP EliteBook 845 G9 Audio Jack Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 845 G9 Audio Jack Replacement, Unfasten the bottom cover: step 2, image 2 of 2
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      • Use a Phillips screwdriver to fully loosen (not remove) the five captive screws securing the bottom cover.
      Ask FixBot
    2. HP EliteBook 845 G9 Audio Jack Replacement, Release the bottom cover clips: step 3, image 1 of 2 HP EliteBook 845 G9 Audio Jack Replacement, Release the bottom cover clips: step 3, image 2 of 2
      • Position your laptop so the rear edge (with the screen hinge) is closest to you.
      • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
      • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
      • Use your spudger to pry up the cover to release the clip securing it.
      • Leave the spudger inserted under the bottom cover for the next step.
      Ask FixBot
    3. HP EliteBook 845 G9 Audio Jack Replacement: step 4, image 1 of 3 HP EliteBook 845 G9 Audio Jack Replacement: step 4, image 2 of 3 HP EliteBook 845 G9 Audio Jack Replacement: step 4, image 3 of 3
      • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
      • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
      Ask FixBot
    4. HP EliteBook 845 G9 Audio Jack Replacement: step 5, image 1 of 3 HP EliteBook 845 G9 Audio Jack Replacement: step 5, image 2 of 3 HP EliteBook 845 G9 Audio Jack Replacement: step 5, image 3 of 3
      • Reinsert the flat end of a spudger near the ELITEBOOK text.
      • Repeat the previous step for the other side of the cover to release the remaining clips.
      Ask FixBot
    5. HP EliteBook 845 G9 Audio Jack Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 845 G9 Audio Jack Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 845 G9 Audio Jack Replacement, Remove the bottom cover: step 6, image 3 of 3
      • Slide the cover towards the screen hinge to disengage the clips on the opposite edge.
      • Lift and remove the cover.
      • The cover should come away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips.
      • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Firmly press around the perimeter of the cover to engage all the clips.
      Ask FixBot
    1. HP EliteBook 845 G9 Audio Jack Replacement, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 845 G9 Audio Jack Replacement, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 845 G9 Audio Jack Replacement, Disconnect the battery: step 7, image 3 of 3
      • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
      • Use the point of a spudger to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
      Ask FixBot
    1. HP EliteBook 845 G9 Audio Jack Replacement, Disconnect the audio jack: step 8, image 1 of 3 HP EliteBook 845 G9 Audio Jack Replacement, Disconnect the audio jack: step 8, image 2 of 3 HP EliteBook 845 G9 Audio Jack Replacement, Disconnect the audio jack: step 8, image 3 of 3
      • Use a spudger to lift the hinged locking flap on the audio jack ZIF connector, located near the top left corner of your laptop.
      • Use tweezers to gently pull the cable straight out of its socket.
      Ask FixBot
    2. HP EliteBook 845 G9 Audio Jack Replacement, Remove the audio jack screw: step 9, image 1 of 2 HP EliteBook 845 G9 Audio Jack Replacement, Remove the audio jack screw: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the 4.6 mm‑long screw securing the audio jack.
      Ask FixBot
    3. HP EliteBook 845 G9 Audio Jack Replacement, Remove the audio jack: step 10, image 1 of 3 HP EliteBook 845 G9 Audio Jack Replacement, Remove the audio jack: step 10, image 2 of 3 HP EliteBook 845 G9 Audio Jack Replacement, Remove the audio jack: step 10, image 3 of 3
      • Use tweezers or your fingers to pull the audio jack away from the edge to dislodge it.
      • Lift the audio jack out of its recess and remove it.
      • During reassembly, insert the audio jack at a slight downward angle so the socket goes into its cutout on the edge of your laptop—make sure the jack is fully inserted before securing it.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Matt Zieminski
50,240 Reputation
28 Guides authored
iFixit Member of iFixit
Staff
123 Members
78,995 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 41
All Time: 528
