HP EliteBook 845 G7 Display Panel Replacement
    1. HP EliteBook 845 G7 Display Panel Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Before you begin: step 1, image 2 of 2
      • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
      • Save your work, fully shut down your laptop, and unplug all cables.
      Ask FixBot
    1. HP EliteBook 845 G7 Display Panel Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Unfasten the bottom cover: step 2, image 2 of 2
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      • Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
      Ask FixBot
    2. HP EliteBook 845 G7 Display Panel Replacement, Release the bottom cover clips: step 3, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Release the bottom cover clips: step 3, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Release the bottom cover clips: step 3, image 3 of 3
      • Position your laptop so the rear edge (with the screen hinge) is closest to you.
      • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
      • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
      • Use your spudger to pry up the cover to release the clip securing it.
      • Leave the spudger inserted under the bottom cover for the next step.
      Ask FixBot
    3. HP EliteBook 845 G7 Display Panel Replacement: step 4, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 4, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 4, image 3 of 3
      • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
      • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
      Ask FixBot
    4. HP EliteBook 845 G7 Display Panel Replacement: step 5, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 5, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 5, image 3 of 3
      • Reinsert the flat end of a spudger near the ELITEBOOK text.
      • Repeat the previous step for the other side of the cover to release the remaining clips.
      Ask FixBot
    5. HP EliteBook 845 G7 Display Panel Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the bottom cover: step 6, image 3 of 3
      • Lift and remove the bottom cover.
      • The cover should lift away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips, and check that all screws are fully loosened.
      • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Press firmly around the perimeter to engage all of the clips.
      Ask FixBot
    1. HP EliteBook 845 G7 Display Panel Replacement, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the battery: step 7, image 3 of 3
      • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
      • Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
      Ask FixBot
    1. HP EliteBook 845 G7 Display Panel Replacement, Disconnect the WLAN module cables: step 8, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the WLAN module cables: step 8, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the WLAN module cables: step 8, image 3 of 3
      • Slide an arm of a pair of angled tweezers under the metal neck of one of the coaxial connectors on the WLAN (Wi-Fi) module, located just below the fan.
      • Lift straight up to disconnect the cable.
      • Repeat to disconnect the second connector.
      • During reassembly:
      • Connect the cable with black tape to the socket with a black arrow below it, and the cable with white tape to the socket with a white arrow.
      • Use tweezers to hold a connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again. Don't use excessive force.
      Ask FixBot
    1. HP EliteBook 845 G7 Display Panel Replacement, Disconnect the display cable: step 9, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the display cable: step 9, image 2 of 2
      • Use your fingers to grip the plastic pull tab on the right display cable press connector, below the fan.
      • Pull straight up to disconnect the connector.
      • During reassembly, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again. Don't use excessive force.
      Ask FixBot
    2. HP EliteBook 845 G7 Display Panel Replacement, Peel up the fan tape: step 10, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Peel up the fan tape: step 10, image 2 of 2
      • Use tweezers or your fingers to peel up the cable tape near the right side of the fan.
      • You don't need to fully remove the tape—it can stay on the cable.
      Ask FixBot
    3. HP EliteBook 845 G7 Display Panel Replacement, De‑route the fan cables: step 11, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, De‑route the fan cables: step 11, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, De‑route the fan cables: step 11, image 3 of 3
      • Use your fingers to pull the display cable and two coaxial cables out from their clips on the right side of the fan.
      • During reassembly, use this photo as a reference to properly route the cables into their clips.
      Ask FixBot
    1. HP EliteBook 845 G7 Display Panel Replacement, Disconnect the power connector cable: step 12, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the power connector cable: step 12, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the power connector cable: step 12, image 3 of 3
      • Use the point of a spudger or your fingernail to push on alternating sides of the power connector's sliding connector to walk it completely out of its socket near the left hinge.
      • Take a Picture: Before removing the cable, you may want to take a photo of the wiring for easy reassembly.
      • During reassembly, make sure the side of the connector marked with a black dot is facing up before reconnecting it.
      Ask FixBot
    2. HP EliteBook 845 G7 Display Panel Replacement: step 13, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement: step 13, image 2 of 2
      • Use tweezers or your fingers to pull the power connector cable out of its clip.
      Ask FixBot
    1. HP EliteBook 845 G7 Display Panel Replacement, Disconnect the display cable: step 14, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the display cable: step 14, image 2 of 2
      • Use your fingers to grip the plastic pull tab on the left display cable press connector, near the left hinge.
      Ask FixBot
    2. HP EliteBook 845 G7 Display Panel Replacement: step 15, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement: step 15, image 2 of 2
      • Use tweezers or your fingers to pull the display cable out of its clip.
      Ask FixBot
    3. HP EliteBook 845 G7 Display Panel Replacement: step 16, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement: step 16, image 2 of 2
      • Use your fingers or tweezers to lift the display and antenna cables out of their clip near the right hinge.
      Ask FixBot
    4. HP EliteBook 845 G7 Display Panel Replacement, Fully open your laptop: step 17, image 1 of 1
      • Fully open your laptop and set it keyboard-side down on a flat, clean work surface, with the display closest you.
      • During reassembly, if your screen clicks or snaps when it's opened or closed, loosen the screws and realign the screen.
      Ask FixBot
    5. HP EliteBook 845 G7 Display Panel Replacement, Remove the hinge screws: step 18, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Remove the hinge screws: step 18, image 2 of 2
      • Use a Phillips screwdriver to remove the six 4.6 mm‑long hinge screws—four in one hinge and two in the other.
      • Before installing any hinge screws, make sure the display is properly aligned.
      • Tighten the hinge screws in ascending order based on the number stamped next to each screw hole.
      Ask FixBot
    6. HP EliteBook 845 G7 Display Panel Replacement, Remove the display: step 19, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the display: step 19, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the display: step 19, image 3 of 3
      • Grip the display assembly near the hinges and lift straight up to remove it.
      • You may need to hold down the main body while guiding the hinges out of their recesses.
      • During reassembly, make sure both hinges on your replacement display assembly are fully open before lowering them into their recesses.
      Ask FixBot
    1. HP EliteBook 845 G7 Display Panel Replacement, Separate the bezel: step 20, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Separate the bezel: step 20, image 2 of 2
      • Push the flat end of a spudger underneath the top edge of the display's plastic bezel, near the top left corner.
      • The plastic bezel is bendable and secures to the display with light adhesive.
      Ask FixBot
    2. HP EliteBook 845 G7 Display Panel Replacement: step 21, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 21, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 21, image 3 of 3
      • Slide the spudger across the top edge, around the top right corner, and down the right edge to separate the adhesive securing the bezel.
      Ask FixBot
    3. HP EliteBook 845 G7 Display Panel Replacement: step 22, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 22, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 22, image 3 of 3
      • Slide the spudger across the bottom edge, around the bottom left corner, and up the left edge to separate the adhesive securing the bezel.
      Ask FixBot
    4. HP EliteBook 845 G7 Display Panel Replacement: step 23, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 23, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 23, image 3 of 3
      • Re-insert the flat end of the spudger underneath the top edge of the display's plastic bezel, near the top left corner.
      • Lift up to peel the bezel away from the display, until you can grip it with your fingers.
      Ask FixBot
    5. HP EliteBook 845 G7 Display Panel Replacement, Remove the bezel: step 24, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the bezel: step 24, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the bezel: step 24, image 3 of 3
      • Once a portion of the bezel lifts to where you can grip it with your fingers, peel the bezel up around the entire perimeter, using the spudger to separate any sections still adhered.
      • Remove the plastic bezel.
      • During reassembly, make sure to remove all the plastic liners and pieces of tape from your replacement bezel. Check thoroughly around the entire perimeter.
      Ask FixBot
    6. HP EliteBook 845 G7 Display Panel Replacement, Unscrew the chin cover: step 25, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Unscrew the chin cover: step 25, image 2 of 2
      • Use a Phillips screwdriver to remove the 2.0 mm-long screw securing the chin cover.
      Ask FixBot
    7. HP EliteBook 845 G7 Display Panel Replacement, Unlock the chin cover: step 26, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Unlock the chin cover: step 26, image 2 of 2
      • Slide the entire chin cover to the right to unlock it.
      Ask FixBot
    8. HP EliteBook 845 G7 Display Panel Replacement, Remove the chin cover: step 27, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the chin cover: step 27, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the chin cover: step 27, image 3 of 3
      • Rotate the chin cover down and away from the display.
      • Remove the chin cover.
      • Before reinstalling the chin cover, make sure all of the cables along the bottom of the screen are tucked into their recess and over the screen hinges. Use this photo as a reference.
      Ask FixBot
    9. HP EliteBook 845 G7 Display Panel Replacement, Remove the screen adhesive strips: step 28, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Remove the screen adhesive strips: step 28, image 2 of 2
      • The display panel attaches to the shell with two stretch-release adhesive strips.
      • Near the bottom right side of the screen, use a pair of tweezers to peel back the black pull tab on the stretch-release adhesive strip until you can grip it with your fingers.
      Ask FixBot
    10. HP EliteBook 845 G7 Display Panel Replacement: step 29, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 29, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 29, image 3 of 3
      • Grab an adhesive strip's pull tab and slowly pull it out from underneath the screen.
      • If using a pair of tweezers, spin the tweezers to wrap the strip up as it releases, pulling as you go.
      • Keep the angle of the adhesive strip as parallel to the display as you can.
      • Pull the adhesive strip until it's freed from under the screen.
      Ask FixBot
    11. HP EliteBook 845 G7 Display Panel Replacement: step 30, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 30, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement: step 30, image 3 of 3
      • Repeat and remove the adhesive strip from the left side of the screen.
      Ask FixBot
    12. HP EliteBook 845 G7 Display Panel Replacement, Free the display cable: step 31, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Free the display cable: step 31, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Free the display cable: step 31, image 3 of 3
      • Pull the display cable out from underneath its routing tab on the shell.
      Ask FixBot
    13. HP EliteBook 845 G7 Display Panel Replacement, Remove the display panel: step 32, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the display panel: step 32, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Remove the display panel: step 32, image 3 of 3
      • Lift and remove the display panel from the shell.
      Ask FixBot
    14. HP EliteBook 845 G7 Display Panel Replacement, Transfer the display cable: step 33, image 1 of 2 HP EliteBook 845 G7 Display Panel Replacement, Transfer the display cable: step 33, image 2 of 2
      • Replacement display panels may or may not come with an included display cable. If it's missing on the replacement, you'll need to transfer the old one over from your original panel.
      • A thin layer of tape covers and protects the display cable connector.
      • Prepare an iOpener and apply it to the screen-side display connector tape for one minute to soften the adhesive.
      • A hair dryer may also be used, but be careful not to overheat the components—keep the hair dryer well above the connector and moving at all times.
      Ask FixBot
    15. HP EliteBook 845 G7 Display Panel Replacement, Peel up the tape: step 34, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Peel up the tape: step 34, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Peel up the tape: step 34, image 3 of 3
      • Use the flat end of a spudger to push up a corner of the tape until you can grip it with a pair of tweezers.
      • Use a pair of tweezers to peel the tape back, over the connector.
      Ask FixBot
    16. HP EliteBook 845 G7 Display Panel Replacement, Disconnect the display cable: step 35, image 1 of 3 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the display cable: step 35, image 2 of 3 HP EliteBook 845 G7 Display Panel Replacement, Disconnect the display cable: step 35, image 3 of 3
      • Use the point of a spudger to lift up the thin metal locking bar on the display connector.
      • Use your fingers to slide the display cable out of its connector.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, starting with the hinge cover step.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Carsten Frauenheim
171,572 Reputation
441 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 32
Past 30 Days: 110
All Time: 1,216
