OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Use this guide to replace a cracked, broken, or damaged bottom cover on your HP EliteBook 845 G7 laptop.
Tools
Spudger4.9
Before starting your repair, save your work, fully shut down your laptop, and unplug all cables.
Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
Position your laptop so the rear edge (with the screen hinge) is closest to you.
Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
Use your spudger to pry up the cover to release the clip securing it.
Leave the spudger inserted under the bottom cover for the next step.
