HP EliteBook 840 G9 Fan Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
34
Past 30 Days:
109
All Time:
1,135
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓
Use this guide to replace the fan in your HP EliteBook 840 G9 laptop.
You may need to replace the fan if it's spinning erratically or not spinning at all.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
Parts
Tools
    1. HP EliteBook 840 G9 Fan Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 840 G9 Fan Replacement, Before you begin: step 1, image 2 of 2
      • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
      • Save your work, fully shut down your laptop, and unplug all cables.
      Ask FixBot
    1. HP EliteBook 840 G9 Fan Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 840 G9 Fan Replacement, Unfasten the bottom cover: step 2, image 2 of 2
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      • Use a Phillips screwdriver to fully loosen (not remove) the five captive screws securing the bottom cover.
      Ask FixBot
    2. HP EliteBook 840 G9 Fan Replacement, Release the bottom cover clips: step 3, image 1 of 2 HP EliteBook 840 G9 Fan Replacement, Release the bottom cover clips: step 3, image 2 of 2
      • Position your laptop so the rear edge (with the screen hinge) is closest to you.
      • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
      • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
      • Use your spudger to pry up the cover to release the clip securing it.
      • Leave the spudger inserted under the bottom cover for the next step.
      Ask FixBot
    3. HP EliteBook 840 G9 Fan Replacement: step 4, image 1 of 3 HP EliteBook 840 G9 Fan Replacement: step 4, image 2 of 3 HP EliteBook 840 G9 Fan Replacement: step 4, image 3 of 3
      • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
      • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
      Ask FixBot
    4. HP EliteBook 840 G9 Fan Replacement: step 5, image 1 of 3 HP EliteBook 840 G9 Fan Replacement: step 5, image 2 of 3 HP EliteBook 840 G9 Fan Replacement: step 5, image 3 of 3
      • Reinsert the flat end of a spudger near the ELITEBOOK text.
      • Repeat the previous step for the other side of the cover to release the remaining clips.
      Ask FixBot
    5. HP EliteBook 840 G9 Fan Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 840 G9 Fan Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 840 G9 Fan Replacement, Remove the bottom cover: step 6, image 3 of 3
      • Slide the cover towards the screen hinge to disengage the clips on the opposite edge.
      • Lift and remove the cover.
      • The cover should come away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips.
      • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Firmly press around the perimeter of the cover to engage all the clips.
      Ask FixBot
    1. HP EliteBook 840 G9 Fan Replacement, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 840 G9 Fan Replacement, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 840 G9 Fan Replacement, Disconnect the battery: step 7, image 3 of 3
      • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
      • Use the point of a spudger to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
      Ask FixBot
    1. HP EliteBook 840 G9 Fan Replacement, Disconnect the display cable: step 8, image 1 of 3 HP EliteBook 840 G9 Fan Replacement, Disconnect the display cable: step 8, image 2 of 3 HP EliteBook 840 G9 Fan Replacement, Disconnect the display cable: step 8, image 3 of 3
      • Use your fingers to grip the plastic pull tab on the left display cable press connector, located below the fan.
      • Pull straight up to disconnect the connector.
      • During reassembly, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again. Don't use excessive force.
      Ask FixBot
    2. HP EliteBook 840 G9 Fan Replacement, Disconnect the WWAN cables: step 9, image 1 of 3 HP EliteBook 840 G9 Fan Replacement, Disconnect the WWAN cables: step 9, image 2 of 3 HP EliteBook 840 G9 Fan Replacement, Disconnect the WWAN cables: step 9, image 3 of 3
      • Slide one arm of a pair of angled tweezers under the metal neck of one of the coaxial connectors on the WWAN (cellular) module.
      • Lift straight up to disconnect the cable.
      • Repeat the process to disconnect the three remaining coaxial connectors.
      • During reassembly:
      • Use the numbered pieces of tape on the cables and their corresponding markings on the WWAN module to correctly connect each cable.
      • Use tweezers to hold a connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again. Don't use excessive force.
      Ask FixBot
    3. HP EliteBook 840 G9 Fan Replacement, De‑route the cables: step 10, image 1 of 3 HP EliteBook 840 G9 Fan Replacement, De‑route the cables: step 10, image 2 of 3 HP EliteBook 840 G9 Fan Replacement, De‑route the cables: step 10, image 3 of 3
      • Use your fingers to pull the display cable and four coaxial cables out of their clips on the left side of the fan.
      • During reassembly, use this photo as a reference to properly route the cables into their clips.
      Ask FixBot
    1. HP EliteBook 840 G9 Fan Replacement, Disconnect the fan: step 11, image 1 of 3 HP EliteBook 840 G9 Fan Replacement, Disconnect the fan: step 11, image 2 of 3 HP EliteBook 840 G9 Fan Replacement, Disconnect the fan: step 11, image 3 of 3
      • Use the point of a spudger to push on alternating sides of the fan's sliding connector to walk it completely out of its socket.
      Ask FixBot
    2. HP EliteBook 840 G9 Fan Replacement, Unfasten the fan: step 12, image 1 of 2 HP EliteBook 840 G9 Fan Replacement, Unfasten the fan: step 12, image 2 of 2
      • Use a Phillips screwdriver to fully loosen (not remove) the three captive screws securing the fan.
      Ask FixBot
    3. HP EliteBook 840 G9 Fan Replacement, Remove the fan: step 13, image 1 of 3 HP EliteBook 840 G9 Fan Replacement, Remove the fan: step 13, image 2 of 3 HP EliteBook 840 G9 Fan Replacement, Remove the fan: step 13, image 3 of 3
      • Lift up the left edge of the fan.
      • Pull the fan towards the laptop's left edge to slide the top right corner out from under the heat sink.
      • Remove the fan.
      • During reassembly, make sure the top right corner of the fan slides under the heat sink.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Day
206,591 Reputation
1,266 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 34
Past 30 Days: 109
All Time: 1,135
