HP EliteBook 840 G7 USB Board Replacement
    1. HP EliteBook 840 G7 USB Board Replacement, Before you begin: step 1, image 1 of 2 HP EliteBook 840 G7 USB Board Replacement, Before you begin: step 1, image 2 of 2
      • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
      • Save your work, fully shut down your laptop, and unplug all cables.
      Ask FixBot
    1. HP EliteBook 840 G7 USB Board Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 840 G7 USB Board Replacement, Unfasten the bottom cover: step 2, image 2 of 2
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      • Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
      Ask FixBot
    2. HP EliteBook 840 G7 USB Board Replacement, Release the bottom cover clips: step 3, image 1 of 3 HP EliteBook 840 G7 USB Board Replacement, Release the bottom cover clips: step 3, image 2 of 3 HP EliteBook 840 G7 USB Board Replacement, Release the bottom cover clips: step 3, image 3 of 3
      • Position your laptop so the rear edge (with the screen hinge) is closest to you.
      • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
      • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
      • Use your spudger to pry up the cover to release the clip securing it.
      • Leave the spudger inserted under the bottom cover for the next step.
      Ask FixBot
    3. HP EliteBook 840 G7 USB Board Replacement: step 4, image 1 of 3 HP EliteBook 840 G7 USB Board Replacement: step 4, image 2 of 3 HP EliteBook 840 G7 USB Board Replacement: step 4, image 3 of 3
      • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
      • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
      Ask FixBot
    4. HP EliteBook 840 G7 USB Board Replacement: step 5, image 1 of 3 HP EliteBook 840 G7 USB Board Replacement: step 5, image 2 of 3 HP EliteBook 840 G7 USB Board Replacement: step 5, image 3 of 3
      • Reinsert the flat end of a spudger near the ELITEBOOK text.
      • Repeat the previous step for the other side of the cover to release the remaining clips.
      Ask FixBot
    5. HP EliteBook 840 G7 USB Board Replacement, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 840 G7 USB Board Replacement, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 840 G7 USB Board Replacement, Remove the bottom cover: step 6, image 3 of 3
      • Lift and remove the bottom cover.
      • The cover should lift away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips, and check that all screws are fully loosened.
      • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Press firmly around the perimeter to engage all of the clips.
      Ask FixBot
    1. HP EliteBook 840 G7 USB Board Replacement, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 840 G7 USB Board Replacement, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 840 G7 USB Board Replacement, Disconnect the battery: step 7, image 3 of 3
      • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
      • Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
      Ask FixBot
    1. HP EliteBook 840 G7 USB Board Replacement, Disconnect the USB board: step 8, image 1 of 3 HP EliteBook 840 G7 USB Board Replacement, Disconnect the USB board: step 8, image 2 of 3 HP EliteBook 840 G7 USB Board Replacement, Disconnect the USB board: step 8, image 3 of 3
      • Use the point of a spudger to push on alternating sides of the USB board sliding connector to walk it completely out of its socket.
      Ask FixBot
    2. HP EliteBook 840 G7 USB Board Replacement: step 9, image 1 of 3 HP EliteBook 840 G7 USB Board Replacement: step 9, image 2 of 3 HP EliteBook 840 G7 USB Board Replacement: step 9, image 3 of 3
      • Use the flat end of a spudger or a clean fingernail to flip up the hinged locking flap on the USB board ZIF connector.
      • Use tweezers or your fingers to gently pull the cable straight out of its socket.
      Ask FixBot
    3. HP EliteBook 840 G7 USB Board Replacement, Remove the USB board screws: step 10, image 1 of 2 HP EliteBook 840 G7 USB Board Replacement, Remove the USB board screws: step 10, image 2 of 2
      • Use a Phillips screwdriver to remove the three 4.5 mm‑long screws securing the USB board.
      Ask FixBot
    4. HP EliteBook 840 G7 USB Board Replacement, Remove the USB board bracket: step 11, image 1 of 2 HP EliteBook 840 G7 USB Board Replacement, Remove the USB board bracket: step 11, image 2 of 2
      • Use your fingers to lift the metal bracket straight up and remove it.
      Ask FixBot
    5. HP EliteBook 840 G7 USB Board Replacement, Remove the USB board: step 12, image 1 of 3 HP EliteBook 840 G7 USB Board Replacement, Remove the USB board: step 12, image 2 of 3 HP EliteBook 840 G7 USB Board Replacement, Remove the USB board: step 12, image 3 of 3
      • Lift the left edge of the USB board and pull it toward the fan to remove the board.
      • During reassembly:
      • Hold the cable out of the way so it doesn't get stuck underneath the board.
      • Slide the ports towards their cutouts in the chassis at a shallow angle, allowing the alignment posts to slot into place.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Day
199,853 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
78,265 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 76
All Time: 777
