HP EliteBook 840 G7 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. HP EliteBook 840 G7 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop on its back.
      Ask FixBot
    2. HP EliteBook 840 G7 Battery Replacement: step 2, image 1 of 1
      • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
      Ask FixBot
    3. HP EliteBook 840 G7 Battery Replacement: step 3, image 1 of 1
      • Remove the back cover to expose the hardware.
      Ask FixBot
    4. HP EliteBook 840 G7 Battery Replacement: step 4, image 1 of 3 HP EliteBook 840 G7 Battery Replacement: step 4, image 2 of 3 HP EliteBook 840 G7 Battery Replacement: step 4, image 3 of 3
      • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
      • Remove the connector that connects the battery to the motherboard.
      Ask FixBot
    5. HP EliteBook 840 G7 Battery Replacement: step 5, image 1 of 3 HP EliteBook 840 G7 Battery Replacement: step 5, image 2 of 3 HP EliteBook 840 G7 Battery Replacement: step 5, image 3 of 3
      • Lift up the battery with you hands or tools.
      Ask FixBot
Pedro Ramos Espinoza
975 Reputation
4 Guides authored
Gateway, Team 1-1, Pee Spring 2022 Member of Gateway, Team 1-1, Pee Spring 2022
GCC-PEE-S22S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 4,051
