HP EliteBook 840 G6 RAM Replacement
    1. HP EliteBook 840 G6 RAM Replacement, Locate RAM: step 1, image 1 of 1
      • Locate the location of the RAM.
      Ask FixBot
    2. HP EliteBook 840 G6 RAM Replacement, Disengage the memory array: step 2, image 1 of 1
      • Spread the spring blades that hold the memory strip in place (left and right).
      Ask FixBot
    3. HP EliteBook 840 G6 RAM Replacement, Remove the memory module: step 3, image 1 of 1
      • With your finger, gently remove the memory module (RAM).
      Ask FixBot
    4. HP EliteBook 840 G6 RAM Replacement, Change memory module (RAM): step 4, image 1 of 2 HP EliteBook 840 G6 RAM Replacement, Change memory module (RAM): step 4, image 2 of 2
      • Place the new memory module (RAM) in its slot.
      • Option: add a second memory module (RAM).
      Ask FixBot
    5. HP EliteBook 840 G6 RAM Replacement, Attach the memory module (RAM): step 5, image 1 of 2 HP EliteBook 840 G6 RAM Replacement, Attach the memory module (RAM): step 5, image 2 of 2
      • Gently press the top of the memory module until the spring blades engage (clicks!).
      Ask FixBot
    6. HP EliteBook 840 G6 RAM Replacement, Insert a second memory module: step 6, image 1 of 1
      • Repeat same procedure as for the first RAM module.
      Ask FixBot
    7. HP EliteBook 840 G6 RAM Replacement, Final result: step 7, image 1 of 1
      • You are done!
      Ask FixBot
Finish Line
5 other people completed this guide.
Eric M2264
708 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 40
Past 30 Days: 175
All Time: 4,462
