HP EliteBook 840 G4 Trackpad Replacement
  1. HP EliteBook 840 G4 Trackpad Replacement, Battery: step 1, image 1 of 3 HP EliteBook 840 G4 Trackpad Replacement, Battery: step 1, image 2 of 3 HP EliteBook 840 G4 Trackpad Replacement, Battery: step 1, image 3 of 3
    • Remove the ten 2 mm screws securing the back panel using a Phillips #0 screwdriver.
    • Pry open the sides using an opening tool until you hear clicks.
    • Pop off the back panel and place it to the side.
    Ask FixBot
  2. HP EliteBook 840 G4 Trackpad Replacement: step 2, image 1 of 3 HP EliteBook 840 G4 Trackpad Replacement: step 2, image 2 of 3 HP EliteBook 840 G4 Trackpad Replacement: step 2, image 3 of 3
    • Remove the two 2 mm screws from the battery using a Phillips #0 screwdriver.
    • Pull up the tab on the battery to remove it from the device.
    Ask FixBot
  3. HP EliteBook 840 G4 Trackpad Replacement, Trackpad: step 3, image 1 of 3 HP EliteBook 840 G4 Trackpad Replacement, Trackpad: step 3, image 2 of 3 HP EliteBook 840 G4 Trackpad Replacement, Trackpad: step 3, image 3 of 3
    • Remove the 17 4 mm screws from the midframe using a Phillips 0 screwdriver.
    • Disconnect the two wires from the Wi-Fi card.
    • Flip up the midframe.
    Ask FixBot
  4. HP EliteBook 840 G4 Trackpad Replacement: step 4, image 1 of 1
    • Remove the tape from the trackpad.
    • Disconnect the blue cable.
    Ask FixBot
  5. HP EliteBook 840 G4 Trackpad Replacement: step 5, image 1 of 2 HP EliteBook 840 G4 Trackpad Replacement: step 5, image 2 of 2
    • Pick up the far side of the trackpad and slide it up and out away from you to disconnect it.
    Ask FixBot
Ka'Myra
220 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 37
All Time: 249
