HP EliteBook 840 G4 Solid State Drive Replacement
  1. HP EliteBook 840 G4 Solid State Drive Replacement, Solid State Drive: step 1, image 1 of 3 HP EliteBook 840 G4 Solid State Drive Replacement, Solid State Drive: step 1, image 2 of 3 HP EliteBook 840 G4 Solid State Drive Replacement, Solid State Drive: step 1, image 3 of 3
    • Remove the ten 2 mm screws securing the back panel using a Phillips #0 screwdriver.
    • Pry open the sides using an opening tool until you hear clicks.
    • Pop off the back panel and place it to the side.
    Ask FixBot
  2. HP EliteBook 840 G4 Solid State Drive Replacement: step 2, image 1 of 1
    • Remove the 2 mm screw holding the SSD in place using a Phillips #0 screwdriver.
    Ask FixBot
  3. HP EliteBook 840 G4 Solid State Drive Replacement: step 3, image 1 of 1
    • Gently pull the SSD out of the slot.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 33
All Time: 239
