HP EliteBook 840 G4 Battery Replacement
  1. HP EliteBook 840 G4 Battery Replacement, Battery: step 1, image 1 of 3 HP EliteBook 840 G4 Battery Replacement, Battery: step 1, image 2 of 3 HP EliteBook 840 G4 Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the ten 2 mm screws securing the back panel using a Phillips #0 screwdriver.
    • Pry open the sides using an opening tool until you hear clicks.
    • Pop off the back panel and place it to the side.
    Ask FixBot
  2. HP EliteBook 840 G4 Battery Replacement: step 2, image 1 of 3 HP EliteBook 840 G4 Battery Replacement: step 2, image 2 of 3 HP EliteBook 840 G4 Battery Replacement: step 2, image 3 of 3
    • Remove the two 2 mm screws from the battery using a Phillips #0 screwdriver.
    • Pull up the tab on the battery to remove it from the device.
    Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 80
All Time: 506
