HP EliteBook 840 G3 SSD Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
33
Past 30 Days:
157
All Time:
4,663
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
      • As always:
      • Unplug the power cord, turn off and remove the battery.
      Ask FixBot
      • Turn the notebook over and remove the Gimmi covers with a small screwdriver.
      Ask FixBot
      • Now unscrew all 9! screws (see arrow) and carefully loosen the lower shell.
      Ask FixBot
      • Now install the new M.2 SSD and fasten it with the small screw (arrow).
      Ask FixBot
      • Now plug the new hard drive into the appropriate connector.
      • Tighten the two screws.
      Ask FixBot
      • Close the notebook with the bottom shell and make sure that everything clicks into place nicely.
      • Screw everything back together and press the small rubber covers tight.
      Ask FixBot
      • Insert the battery.
      • Turn on the device.
      • Reinstall Windows or format the new hard drive if you installed it as an add-on hard drive.
      Ask FixBot
Work the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Robert ts
172 Reputation
1 Guide authored
1 Guide Comment
Buenas tardes tengo una hp 840 g3 no me da imagen la pantalla
john dorante - Reply Share
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 157
All Time: 4,663
