HP EliteBook 830 G6 Wi-Fi Card Replacement
    1. HP EliteBook 830 G6 Wi-Fi Card Replacement, Bottom Cover Panel: step 1, image 1 of 1
      • Use a JIS #1 screwdriver to remove the five 10.7 mm screws from the bottom cover.
      Ask FixBot
    2. HP EliteBook 830 G6 Wi-Fi Card Replacement: step 2, image 1 of 1
      • With your spudger you will pry off the bottom panel with some force.
      Ask FixBot
    1. HP EliteBook 830 G6 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 3 HP EliteBook 830 G6 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 2 of 3 HP EliteBook 830 G6 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 3 of 3
      • Find the storage drive, located on the left side. It is secured with one 2.48 mm screw and connected to 2 cords
      • Carefully remove the one 2.48mm screw with a Phillips #1 screwdriver holding the storage drive in place.
      • Gently pull up on the 2 cords connected to it.
      Ask FixBot
    2. HP EliteBook 830 G6 Wi-Fi Card Replacement: step 4, image 1 of 2 HP EliteBook 830 G6 Wi-Fi Card Replacement: step 4, image 2 of 2
      • Gently slide the drive out of its connector. Avoid bending or applying force to the connector.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Cadence Hohertz
457 Reputation
5 Guides authored
Texas Tech, Team 37-5, Allen Fall 2025 Member of Texas Tech, Team 37-5, Allen Fall 2025
TTU-ALLEN-F25S37G5
3 Members
78 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 31
All Time: 167
