HP EliteBook 830 G6 RAM Replacement
    1. HP EliteBook 830 G6 RAM Replacement, Bottom Cover Panel: step 1, image 1 of 1
      • Use a JIS #1 screwdriver to remove the five 10.7 mm screws from the bottom cover.
      Ask FixBot
    2. HP EliteBook 830 G6 RAM Replacement: step 2, image 1 of 1
      • With your spudger you will pry off the bottom panel with some force.
      Ask FixBot
    1. HP EliteBook 830 G6 RAM Replacement, RAM: step 3, image 1 of 2 HP EliteBook 830 G6 RAM Replacement, RAM: step 3, image 2 of 2
      • Use a spudger to disconnect the battery connector from the motherboard.
      • Avoid pulling on the cables as this can damage the connector or socket.
      Ask FixBot
    2. HP EliteBook 830 G6 RAM Replacement: step 4, image 1 of 3 HP EliteBook 830 G6 RAM Replacement: step 4, image 2 of 3 HP EliteBook 830 G6 RAM Replacement: step 4, image 3 of 3
      • Pull the two metal brackets on the sides of both RAM sticks outward with a spudger or your fingers.
      • This should allow them to pop up at an angle.
      Ask FixBot
    3. HP EliteBook 830 G6 RAM Replacement: step 5, image 1 of 1
      • Pull the stick of RAM out of its socket to remove it.
      • Repeat for a second stick of RAM.
      • To install a memory module, insert it into its socket at a slight downward angle, then push down firmly until both metal arms lock the RAM in place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Haley Johnson
211 Reputation
2 Guides authored
Texas Tech, Team 37-5, Allen Fall 2025 Member of Texas Tech, Team 37-5, Allen Fall 2025
TTU-ALLEN-F25S37G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 100
All Time: 399
