HP EliteBook 830 G6 Fan Replacement
    1. HP EliteBook 830 G6 Fan Replacement, Bottom Cover Panel: step 1, image 1 of 1
      • Use a JIS #1 screwdriver to remove the five 10.7 mm screws from the bottom cover.
      Ask FixBot
    2. HP EliteBook 830 G6 Fan Replacement: step 2, image 1 of 1
      • With your spudger you will pry off the bottom panel with some force.
      Ask FixBot
    1. HP EliteBook 830 G6 Fan Replacement, Fan: step 3, image 1 of 2 HP EliteBook 830 G6 Fan Replacement, Fan: step 3, image 2 of 2
      • Use your J1 but to remove the screw of the heat sink and detach the adhesive connecting it to the fan.
      Ask FixBot
    2. HP EliteBook 830 G6 Fan Replacement: step 4, image 1 of 1
      • Disconnect the fan’s power cable and remove the 3 screws securing it in place with your J1 screwdrivers.
      Ask FixBot
    3. HP EliteBook 830 G6 Fan Replacement: step 5, image 1 of 1
      • Remove tiny bolt and remove fan.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Cadence Hohertz
457 Reputation
5 Guides authored
Texas Tech, Team 37-5, Allen Fall 2025 Member of Texas Tech, Team 37-5, Allen Fall 2025
TTU-ALLEN-F25S37G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 99
All Time: 362
