HP EliteBook 830 G6 Battery Replacement
    1. HP EliteBook 830 G6 Battery Replacement, Bottom Cover Panel: step 1, image 1 of 1
      • Use a JIS #1 screwdriver to remove the five 10.7 mm screws from the bottom cover.
      Ask FixBot
    2. HP EliteBook 830 G6 Battery Replacement: step 2, image 1 of 1
      • With your spudger you will pry off the bottom panel with some force.
      Ask FixBot
    1. HP EliteBook 830 G6 Battery Replacement, Battery: step 3, image 1 of 2 HP EliteBook 830 G6 Battery Replacement, Battery: step 3, image 2 of 2
      • Use a JIS #1 screwdriver to remove the five 4.7 mm screws securing the battery.
      Ask FixBot
    2. HP EliteBook 830 G6 Battery Replacement: step 4, image 1 of 1
      • Gently disconnect the battery cord from motherboard using a plastic spudger.
      Ask FixBot
    3. HP EliteBook 830 G6 Battery Replacement: step 5, image 1 of 1
      • Remove the battery from the laptop.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Haley Johnson
211 Reputation
2 Guides authored
Texas Tech, Team 37-5, Allen Fall 2025 Member of Texas Tech, Team 37-5, Allen Fall 2025
TTU-ALLEN-F25S37G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 128
All Time: 655
