HP EliteBook 820 G3 RAM Replacement
    1. HP EliteBook 820 G3 RAM Replacement, Back Cover: step 1, image 1 of 2 HP EliteBook 820 G3 RAM Replacement, Back Cover: step 1, image 2 of 2
      • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
      • Keep track of where the screw covers were attached to as there are four different sizes.
      Ask FixBot
    2. HP EliteBook 820 G3 RAM Replacement: step 2, image 1 of 2 HP EliteBook 820 G3 RAM Replacement: step 2, image 2 of 2
      • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
      • Lift off the back cover with your hands.
      Ask FixBot
    1. HP EliteBook 820 G3 RAM Replacement, RAM: step 3, image 1 of 3 HP EliteBook 820 G3 RAM Replacement, RAM: step 3, image 2 of 3 HP EliteBook 820 G3 RAM Replacement, RAM: step 3, image 3 of 3
      • Pull the two clips on either side of the RAM sideways at the same time.
      • The top half of the stick will pop out of its plate.
      • Pull the RAM stick out.
      • Repeat this step with the other RAM stick.
      Ask FixBot
2 other people completed this guide.
Nubia Pineda
79 Reputation
1 Guide authored
Gateway, Team 1-1, Class Fall 2022 Member of Gateway, Team 1-1, Class Fall 2022
GCC-CLASS-F22S1G1
4 Members
60 Guides authored
1 Guide Comment
How to reset BIOS password on the HP 820 G3 please? Many thanks.
Jaeram - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 102
All Time: 1,490
