HP EliteBook 820 G3 Keyboard Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
8
Past 7 Days:
48
Past 30 Days:
158
All Time:
3,061
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the keyboard for the HP EliteBook 820 G3 laptop. If any of the keys do not work or the small track pad on the keyboard does not work, the keyboard will need to be replaced. Before beginning, power off the device and disconnect any external power supply.
Tools
    1. HP EliteBook 820 G3 Keyboard Replacement, Back Cover: step 1, image 1 of 2 HP EliteBook 820 G3 Keyboard Replacement, Back Cover: step 1, image 2 of 2
      • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
      • Keep track of where the screw covers were attached to as there are four different sizes.
      Ask FixBot
    2. HP EliteBook 820 G3 Keyboard Replacement: step 2, image 1 of 2 HP EliteBook 820 G3 Keyboard Replacement: step 2, image 2 of 2
      • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
      • Lift off the back cover with your hands.
      Ask FixBot
    1. HP EliteBook 820 G3 Keyboard Replacement, Keyboard: step 3, image 1 of 2 HP EliteBook 820 G3 Keyboard Replacement, Keyboard: step 3, image 2 of 2
      • Remove the two 3.4 mm keyboard screws found near the fan and on top of the hard drive using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP EliteBook 820 G3 Keyboard Replacement: step 4, image 1 of 3 HP EliteBook 820 G3 Keyboard Replacement: step 4, image 2 of 3 HP EliteBook 820 G3 Keyboard Replacement: step 4, image 3 of 3
      • Use an iFixit opening pick to gently pry open the top of the keyboard.
      • Gently pull the keyboard up until you can see the three ribbons under the keyboard.
      Ask FixBot
    3. HP EliteBook 820 G3 Keyboard Replacement: step 5, image 1 of 3 HP EliteBook 820 G3 Keyboard Replacement: step 5, image 2 of 3 HP EliteBook 820 G3 Keyboard Replacement: step 5, image 3 of 3
      • Lift up the latch holding down the ribbon and pull the ribbon out once it is lifted.
      • Repeat for all three of the ribbons.
      • The white ribbon (left ribbon) sometimes does not come with a new keyboard. You may need to detach it and add it to the replacement if necessary.
      Ask FixBot
6 other people completed this guide.
Caleb Morales
226 Reputation
1 Guide authored
Gateway, Team 1-1, Class Fall 2022 Member of Gateway, Team 1-1, Class Fall 2022
GCC-CLASS-F22S1G1
4 Members
60 Guides authored
1 Guide Comment
I did this, it won’t stay in.
Serial Action - Reply Share
Past 24 Hours: 8
Past 7 Days: 48
Past 30 Days: 158
All Time: 3,061
