HP EliteBook 755 G5 Battery Replacement
      • Turn off the computer. If you are unsure whether the computer is in Hibernation, turn the computer on, and then shut it down through the operating system.
      • Disconnect the power from the computer by unplugging the power cord from the computer.
      • Disconnect all external devices from the computer.
      Ask FixBot
    1. HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: step 2, image 1 of 2 HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: step 2, image 2 of 2
      • Turn the computer upside down on a flat surface.
      • Loosen the eight captive screws that secure the bottom cover.
      • Loosen the two inset captive screws that secure the bottom cover.
      • Starting under the middle of the display, pry and lift the bottom cover off the computer.
      Ask FixBot
    2. HP EliteBook 755 G5 Battery Replacement, Disconnect the battery: step 3, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Remove the four Torx T8 2.0×4.0 screws.
      Ask FixBot
    3. HP EliteBook 755 G5 Battery Replacement, Remove the battery: step 4, image 1 of 1
      • Rotate the top of the battery upward, and then lift the battery out of the computer.
      Ask FixBot
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
42,195 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 100
All Time: 2,368
