HP EliteBook 745 G6 RAM Replacement
    1. HP EliteBook 745 G6 RAM Replacement, RAM: step 1, image 1 of 1
      • Type CMD in the Start Menu and open Command Prompt.
      • Type the following command to view memory details and press Enter.
      • wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor.
      Ask FixBot
    2. HP EliteBook 745 G6 RAM Replacement: step 2, image 1 of 1
      • Power off the Notebook.
      • Select the Start button.
      • Select the Power button.
      • Select Shut down.
      • Disconnect the power adapter.
      Ask FixBot
    3. HP EliteBook 745 G6 RAM Replacement: step 3, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 3, image 2 of 2
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Turn the notebook upside down on a flat surface.
      • Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
      • Pry the bottom cover with plastic card or spudger at the bottom right corner.
      • Lift the bottom cover off with plastic card.
      Ask FixBot
    4. HP EliteBook 745 G6 RAM Replacement: step 4, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 4, image 2 of 2
      Anti-Static Wrist Strap
      $7.95
      Buy
      Ask FixBot
    5. HP EliteBook 745 G6 RAM Replacement: step 5, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 5, image 2 of 2
      • Be sure to ground yourself by wearing anti-static wrist strap.
      • Do not remove memory shielding from the system board when replacing memory.
      • The socket labeled 2 houses the expansion memory module and the socket labeled 1 houses the primary memory module.
      • Spread the retaining tabs on each side of the memory module slot to release the memory module.
      • Pull the memory module away from the slot at an angle.
      Ask FixBot
    6. HP EliteBook 745 G6 RAM Replacement: step 6, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 6, image 2 of 2
      • Insert the memory module into the slot at an angle.
      • Push down the center of memory module until the retaining tabs lock the RAM stick.
      Ask FixBot
    7. HP EliteBook 745 G6 RAM Replacement: step 7, image 1 of 1
      • Insert the battery cable into the system board.
      Ask FixBot
    8. HP EliteBook 745 G6 RAM Replacement: step 8, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 8, image 2 of 2
      • Push down the bottom cover at the four corner and center.
      • Tighten the six captive screws and the two inset captive screws clockwise with Phillips #00 screwdriver.
      Ask FixBot
    9. HP EliteBook 745 G6 RAM Replacement: step 9, image 1 of 1
      • Push the power button.
      Ask FixBot
    10. HP EliteBook 745 G6 RAM Replacement: step 10, image 1 of 2 HP EliteBook 745 G6 RAM Replacement: step 10, image 2 of 2
      • Right-click on the taskbar.
      • Select the “Task Manager”.
      • Select the "Performance".
      Ask FixBot
2 other people completed this guide.
Mengqi Shi
232 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 149
All Time: 4,526
