HP EliteBook 745 G4 Battery Replacement
      • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
      • Disconnect the power from the computer by unplugging the power cord from the computer.
      • Disconnect all external devices from the computer.
      • Turn the computer upside down on a flat surface.
      Ask FixBot
    1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: step 2, image 1 of 1
      • Remove the 10 rubber plugs from the bottom cover.
      • Remove the SD card blank from the bottom cover.
      Ask FixBot
    2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: step 3, image 1 of 2 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: step 3, image 2 of 2
      • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
      • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
      Ask FixBot
    3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: step 4, image 1 of 1
      • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
      Ask FixBot
    4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: step 5, image 1 of 1
      • Loosen the two captive screws and remove the battery from the computer
      Ask FixBot
To replace the battery & reassemble your device, follow these instructions in reverse order.
6 other people completed this guide.
Max Kletskov
42,079 Reputation
16 Guides authored
3 Guide Comments
super leicht
Manuel Krannich - Reply Share
you forgot to put the instructions for after the battery is installed when you boot it up You’ll get non-HP battery detected asking you to press enter on every boot. How is this problem fixed?
Richard B - Reply Share
Gilt auch für 745 G3, danke.
Norbert Hasler - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 56
All Time: 2,512
