HP EliteBook 745 G2 RAM Chip Replacement
    1. HP EliteBook 745 G2 RAM Chip Replacement, Battery: step 1, image 1 of 1
      • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
      Ask FixBot
    2. HP EliteBook 745 G2 RAM Chip Replacement: step 2, image 1 of 2 HP EliteBook 745 G2 RAM Chip Replacement: step 2, image 2 of 2
      • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
      Ask FixBot
    3. HP EliteBook 745 G2 RAM Chip Replacement: step 3, image 1 of 2 HP EliteBook 745 G2 RAM Chip Replacement: step 3, image 2 of 2
      • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
      Ask FixBot
    1. HP EliteBook 745 G2 RAM Chip Replacement, RAM Chip: step 4, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      Ask FixBot
    2. HP EliteBook 745 G2 RAM Chip Replacement: step 5, image 1 of 1
      • Using the spudger, gently press down on the tabs holding the chip to release it. Repeat this step for the other chip.
      Ask FixBot
    3. HP EliteBook 745 G2 RAM Chip Replacement: step 6, image 1 of 1
      • Grab the chip and lift it away from the laptop at a 45 degree angle.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 57
All Time: 910
