HP EliteBook 745 G2 Cooling System Replacement
    1. HP EliteBook 745 G2 Cooling System Replacement, Battery: step 1, image 1 of 1
      • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
      Ask FixBot
    2. HP EliteBook 745 G2 Cooling System Replacement: step 2, image 1 of 2 HP EliteBook 745 G2 Cooling System Replacement: step 2, image 2 of 2
      • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
      Ask FixBot
    3. HP EliteBook 745 G2 Cooling System Replacement: step 3, image 1 of 2 HP EliteBook 745 G2 Cooling System Replacement: step 3, image 2 of 2
      • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
      Ask FixBot
    1. HP EliteBook 745 G2 Cooling System Replacement, Cooling System: step 4, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      Ask FixBot
    2. HP EliteBook 745 G2 Cooling System Replacement: step 5, image 1 of 2 HP EliteBook 745 G2 Cooling System Replacement: step 5, image 2 of 2
      • Using a Phillips #0, remove all seven of the 1.5 mm screws on the black plastic housing. Once all the screws are removed lift the plastic cover away.
      • Remove the SD card slot cover and remove the 1.5 mm Phillips #0 screw located in the slot.
      Ask FixBot
    3. HP EliteBook 745 G2 Cooling System Replacement: step 6, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the remaining five 1.5 mm screws holding the cooling system and fan to the motherboard.
      Ask FixBot
    4. HP EliteBook 745 G2 Cooling System Replacement: step 7, image 1 of 1
      • Lift the fan and cooling system upwards until they become free from the computer.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 34
All Time: 2,600
