HP EliteBook 725 G4 Fans Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
54
All Time:
116
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the cooling fan in an HP EliteBook 725 G4.
The laptop uses a 4-pin, 5V DC fan with an aluminum heat sink to remove heat and push warm air out of the laptop.
A failing fan may make grinding noises, stop spinning, or cause overheating and shutdowns. Before replacing it, check the vents for dust and wipe the outside with a dry microfiber cloth.
Parts
Tools
    1. HP EliteBook 725 G4 Fans Replacement, Back Plate: step 1, image 1 of 2 HP EliteBook 725 G4 Fans Replacement, Back Plate: step 1, image 2 of 2
      • Turn off the computer and make sure the computer is not plugged in.
      • Flip the laptop over on its top.
      Ask FixBot
    2. HP EliteBook 725 G4 Fans Replacement: step 2, image 1 of 3 HP EliteBook 725 G4 Fans Replacement: step 2, image 2 of 3 HP EliteBook 725 G4 Fans Replacement: step 2, image 3 of 3
      • Remove eleven 5 mm screws using a Phillips #0 screwdriver.
      • Remove the SD card insert.
      • Remove the last screw under the SD card insert.
      Ask FixBot
    3. HP EliteBook 725 G4 Fans Replacement: step 3, image 1 of 1
      • Use an opening pick to remove the back plate.
      Ask FixBot
    1. HP EliteBook 725 G4 Fans Replacement, Fans: step 4, image 1 of 3 HP EliteBook 725 G4 Fans Replacement, Fans: step 4, image 2 of 3 HP EliteBook 725 G4 Fans Replacement, Fans: step 4, image 3 of 3
      • Remove four screws from the CPU.
      • Remove four 4 mm screws holding the fan down using a Phillips #00 screwdriver.
      • Remove the fan.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 54
All Time: 116
