HP EliteBook 725 G3 Solid State Drive (SSD) Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
63
All Time:
262
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your HP EliteBook 725 G3 is frequently crashing, your files are becoming inaccessible, or everything has just become significantly slower, you may have a failing solid-state drive. Use this guide to properly remove the current SSD for replacement.
An SSD is the primary storage device of a computer. Its main function is to permanently store and retrieve all of the data inside your device. This allows you to save and access your files and save/launch applications.
To prevent any data loss if you suspect you have a failing SSD make sure to regularly backup your device and attempt to leave at least 20-25% of free space in the drive for an optimal performance. Also ensure your cooling system is working properly. You can use the following troubleshooting page, linked here, for tips on preventing overheating of your HP EliteBook 725 G3. Otherwise, if issues persist with your storage, follow this guide.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. HP EliteBook 725 G3 Solid State Drive (SSD) Replacement, Battery: step 1, image 1 of 1
      • Remove the two 2.5 mm Phillips #00 screws securing the battery.
      Ask FixBot
    2. HP EliteBook 725 G3 Solid State Drive (SSD) Replacement: step 2, image 1 of 3 HP EliteBook 725 G3 Solid State Drive (SSD) Replacement: step 2, image 2 of 3 HP EliteBook 725 G3 Solid State Drive (SSD) Replacement: step 2, image 3 of 3
      • Lift and remove the battery.
      Ask FixBot
    1. HP EliteBook 725 G3 Solid State Drive (SSD) Replacement, SSD: step 3, image 1 of 1
      • Remove the single Phillips #00 screw securing the SSD.
      Ask FixBot
    2. HP EliteBook 725 G3 Solid State Drive (SSD) Replacement: step 4, image 1 of 3 HP EliteBook 725 G3 Solid State Drive (SSD) Replacement: step 4, image 2 of 3 HP EliteBook 725 G3 Solid State Drive (SSD) Replacement: step 4, image 3 of 3
      • Pull the SSD directly out of its socket.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Genevieve Picard
306 Reputation
2 Guides authored
UMass Dartmouth, Team 1-4, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-4, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 63
All Time: 262
