Introduction
If your HP EliteBook 725 G3 is continuously experiencing malfunctions like a combination of failing to boot, frequent crashes, unresponsive ports, or POST error codes/beeps then your motherboard may be malfunctioning. Use this guide to properly remove and replace the motherboard.
The motherboard acts as a central hub or the backbone of your device. It connects and allows the hardware components to communicate with each other. The motherboard holds everything together and allows for the device to function as one cohesive unit.
Before using this guide, please see our other troubleshooting pages (linked here), or other guides for replacing components if your symptoms are more specific to a piece of hardware (linked here). However, if all of the issues your experiencing continue to persist afterwards, please follow this guide.
Remove the six 2.5 mm-long Phillips #00 screws securing the fan and heat sink assembly.
Remove the single Phillips #00 screw securing the Wi-Fi card.
Use the pointed end of a spudger to pry up and disconnect the two coaxial connectors.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
