HP EliteBook 725 G3 Lower Case Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
12
Past 30 Days:
64
All Time:
198
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the lower case on a HP EliteBook 725 G3.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. HP EliteBook 725 G3 Lower Case Replacement, Lower Case: step 1, image 1 of 2 HP EliteBook 725 G3 Lower Case Replacement, Lower Case: step 1, image 2 of 2
      • Remove the ten 2.5 mm-long Phillips #0 screws securing the lower case.
      Ask FixBot
    2. HP EliteBook 725 G3 Lower Case Replacement: step 2, image 1 of 2 HP EliteBook 725 G3 Lower Case Replacement: step 2, image 2 of 2
      • Use the pointed tip of a spudger to remove the rubber stoppers on the lower case.
      Ask FixBot
    3. HP EliteBook 725 G3 Lower Case Replacement: step 3, image 1 of 3 HP EliteBook 725 G3 Lower Case Replacement: step 3, image 2 of 3 HP EliteBook 725 G3 Lower Case Replacement: step 3, image 3 of 3
      • Remove the remaining 2.5 mm-long Phillips screws that secure the lower case.
      • There should be 11 total 2.5 mm-long Phillips #0 screws when you're done.
      • Thelower has a click-release mechanism that is shown in the photos where the SD card is inserted.
      • Push in on this mechanism and remove the lower case.
      Ask FixBot
Connor Bassolino
26,177 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 64
All Time: 198
