Up to 20% off select tools
HP EliteBook 2540p
Views: 1.9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
22
Past 30 Days:
122
All Time:
1,915
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 7 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
HP EliteBook 2540p
Parts
Tools
Introduction
Go to step 1 ↓
Pretty bad pictures, taken on my cheap webcam, sorry!
If you have the same device and are willing to take better photos that'd be great.
------------------------------------------------------------------------------------------------Reason for making this: Saw no page for the HP 2540p, so I am posting it here. Also didn't see many YouTube videos showing this.
Keep in mind, that this is my first "contribution."
    1. HP EliteBook 2540p, Taking the Battery Out.: step 1, image 1 of 3 HP EliteBook 2540p, Taking the Battery Out.: step 1, image 2 of 3 HP EliteBook 2540p, Taking the Battery Out.: step 1, image 3 of 3
      • Power off the computer if you have it on, and flip it over.
      • Pull both things on the side of the battery.
      • While still pulling both of them back, take out the battery, it should just slip out.
      Ask FixBot
    2. HP EliteBook 2540p, Removing cover and installing drive/RAM: step 2, image 1 of 3 HP EliteBook 2540p, Removing cover and installing drive/RAM: step 2, image 2 of 3 HP EliteBook 2540p, Removing cover and installing drive/RAM: step 2, image 3 of 3
      • While Still on the back, look for a plastic cover that says "HP 3D DriveGuard." (AKA. the longest cover)
      • Unscrew it, there are 3 Philips screws on it.
      • Personally, I do not have a drive in it right now, but you will need a 1.8-inch drive to fit it into the laptop. Plug the SATA Drive into the connector.
      • For the ram pull the two gray things a bit and then take out or put in the ram at an angle.
      Ask FixBot
Put the cover back on and screw it in, then you can put the battery back in as well.
Author
with
lunar
85 Reputation
1 Guide authored
1 Guide Comment
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/165266235415
jacques_06
jacques_06 - Reply Share
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 122
All Time: 1,915
