HP EliteBook 1050 G1 RAM Replacement
    1. HP EliteBook 1050 G1 RAM Replacement, RAM: step 1, image 1 of 2 HP EliteBook 1050 G1 RAM Replacement, RAM: step 1, image 2 of 2
      • Remove the five 8.7mm screws with a Torx T8 driver.
      • Remove the two 5.5mm screws with a Torx T8 driver.
      • Remove the two 6.6mm screws with a Torx T8 driver.
      • Lift open the back panel with a Jimmy.
      Ask FixBot
    2. HP EliteBook 1050 G1 RAM Replacement: step 2, image 1 of 3 HP EliteBook 1050 G1 RAM Replacement: step 2, image 2 of 3 HP EliteBook 1050 G1 RAM Replacement: step 2, image 3 of 3
      • Pull the clips on either side of the RAM chip away from each other using your fingers.
      • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
      • Slide the RAM chips out of their respective slots.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 66
All Time: 783
