HP EliteBook 1040 G4 Trackpad Replacement
    1. HP EliteBook 1040 G4 Trackpad Replacement, Back Cover: step 1, image 1 of 1
      • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
      Ask FixBot
    2. HP EliteBook 1040 G4 Trackpad Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Trackpad Replacement: step 2, image 2 of 2
      • Lift the back cover up and off the device.
      Ask FixBot
    1. HP EliteBook 1040 G4 Trackpad Replacement, Battery: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
      Ask FixBot
    2. HP EliteBook 1040 G4 Trackpad Replacement: step 4, image 1 of 2 HP EliteBook 1040 G4 Trackpad Replacement: step 4, image 2 of 2
      • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
      Ask FixBot
    3. HP EliteBook 1040 G4 Trackpad Replacement: step 5, image 1 of 2 HP EliteBook 1040 G4 Trackpad Replacement: step 5, image 2 of 2
      • Lift and remove the battery from the device.
      Ask FixBot
    1. HP EliteBook 1040 G4 Trackpad Replacement, Trackpad: step 6, image 1 of 1
      • Peel back the foam cover to reveal the underside of the trackpad.
      Ask FixBot
    2. HP EliteBook 1040 G4 Trackpad Replacement: step 7, image 1 of 1
      • Carefully disconnect the white ribbon cable attached to the underside of the trackpad.
      Ask FixBot
    3. HP EliteBook 1040 G4 Trackpad Replacement: step 8, image 1 of 1
      • Carefully disconnect the black ribbon cable attached to the chassis.
      Ask FixBot
    4. HP EliteBook 1040 G4 Trackpad Replacement: step 9, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the six 2 mm screws securing the trackpad.
      Ask FixBot
    5. HP EliteBook 1040 G4 Trackpad Replacement: step 10, image 1 of 1
      • Lift and remove the trackpad from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 70
All Time: 792
