HP EliteBook 1040 G4 Fan Replacement
    1. HP EliteBook 1040 G4 Fan Replacement, Back Cover: step 1, image 1 of 1
      • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
      Ask FixBot
    2. HP EliteBook 1040 G4 Fan Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Fan Replacement: step 2, image 2 of 2
      • Lift the back cover up and off the device.
      Ask FixBot
    1. HP EliteBook 1040 G4 Fan Replacement, Fan: step 3, image 1 of 2 HP EliteBook 1040 G4 Fan Replacement, Fan: step 3, image 2 of 2
      • Using the Phillips #0 screwdriver, remove the two silver 5 mm screws surrounding the fan.
      • The top left screw may be hidden under shielding tape.
      Ask FixBot
    2. HP EliteBook 1040 G4 Fan Replacement: step 4, image 1 of 3 HP EliteBook 1040 G4 Fan Replacement: step 4, image 2 of 3 HP EliteBook 1040 G4 Fan Replacement: step 4, image 3 of 3
      • Remove the electrical tape to expose the heat sink screws.
      • Using the Phillips #0 screwdriver, unscrew the four screws securing the heatsink to the motherboard.
      • Carefully disconnect the pin connector by pulling it from its slot.
      Ask FixBot
    3. HP EliteBook 1040 G4 Fan Replacement: step 5, image 1 of 1
      • Carefully remove the wires from the clip to the left of the fan.
      Ask FixBot
    4. HP EliteBook 1040 G4 Fan Replacement: step 6, image 1 of 2 HP EliteBook 1040 G4 Fan Replacement: step 6, image 2 of 2
      • Lift and remove the fan and heatsink assembly from the device.
      Ask FixBot
Hannah DiMartino
416 Reputation
3 Guides authored
Clemson, Team 4-1, Hunter Fall 2021 Member of Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 1,200
