HP EliteBook 1040 G4 Display Replacement
    1. HP EliteBook 1040 G4 Display Replacement, Display: step 1, image 1 of 1
      • Wedge an opening tool between the display and the chassis, gently prying around the perimeter until the display completely releases.
      Ask FixBot
    2. HP EliteBook 1040 G4 Display Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Display Replacement: step 2, image 2 of 2
      • Lift the metal arm, then pull the display ribbon cable directly out of its port.
      Ask FixBot
    3. HP EliteBook 1040 G4 Display Replacement: step 3, image 1 of 2 HP EliteBook 1040 G4 Display Replacement: step 3, image 2 of 2
      • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
      Ask FixBot
    4. HP EliteBook 1040 G4 Display Replacement: step 4, image 1 of 1
      • Remove the hinge cover.
      Ask FixBot
    5. HP EliteBook 1040 G4 Display Replacement: step 5, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the three 5 mm black screws that securing the dispaly.
      Ask FixBot
    6. HP EliteBook 1040 G4 Display Replacement: step 6, image 1 of 2 HP EliteBook 1040 G4 Display Replacement: step 6, image 2 of 2
      • Lift the display up and out of its housing.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 85
All Time: 1,959
