HP EliteBook 1040 G4 Battery Replacement
    1. HP EliteBook 1040 G4 Battery Replacement, Back Cover: step 1, image 1 of 1
      • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
      Ask FixBot
    2. HP EliteBook 1040 G4 Battery Replacement: step 2, image 1 of 2 HP EliteBook 1040 G4 Battery Replacement: step 2, image 2 of 2
      • Lift the back cover up and off the device.
      Ask FixBot
    1. HP EliteBook 1040 G4 Battery Replacement, Battery: step 3, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
      Ask FixBot
    2. HP EliteBook 1040 G4 Battery Replacement: step 4, image 1 of 2 HP EliteBook 1040 G4 Battery Replacement: step 4, image 2 of 2
      • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
      Ask FixBot
    3. HP EliteBook 1040 G4 Battery Replacement: step 5, image 1 of 2 HP EliteBook 1040 G4 Battery Replacement: step 5, image 2 of 2
      • Lift and remove the battery from the device.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Hannah DiMartino
416 Reputation
3 Guides authored
Clemson, Team 4-1, Hunter Fall 2021 Member of Clemson, Team 4-1, Hunter Fall 2021
CLEM-HUNTER-F21S4G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 43
All Time: 2,162
