HP Elite x2 G4 Battery Replacement
    1. HP Elite x2 G4 Battery Replacement, Screen: step 1, image 1 of 2 HP Elite x2 G4 Battery Replacement, Screen: step 1, image 2 of 2
      • Open the kickstand.
      • Use a T5 Torx screwdriver to remove the four 3.0 mm screws along the bottom edge of the back of the display assembly.
      Ask FixBot
    2. HP Elite x2 G4 Battery Replacement: step 2, image 1 of 3 HP Elite x2 G4 Battery Replacement: step 2, image 2 of 3 HP Elite x2 G4 Battery Replacement: step 2, image 3 of 3
      • Use a suction cup and opening pick to carefully detach the screen from the display assembly in the following order: top-right, top-left, bottom-right, and bottom-left corners.
      • Slide an opening pick around the seam between the screen and back case to release the retaining clips.
      • Leave an opening pick in the space along the perimeter to keep the screen reattaching.
      • Use the suction cup to separate the screen.
      Ask FixBot
    3. HP Elite x2 G4 Battery Replacement: step 3, image 1 of 3 HP Elite x2 G4 Battery Replacement: step 3, image 2 of 3 HP Elite x2 G4 Battery Replacement: step 3, image 3 of 3
      • When lifting the display panel, make sure not to lift it too high, since you'll run the risk of tearing the cables, or damaging the connectors on the board.
      • Slowly lift the display panel until you have access to the battery connector on the motherboard.
      • Use a spudger or a clean fingernail to flip up the black locking flap on the ZIF connector to release the display cable from the motherboard.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Use tweezers to gently pull the display cable out of its socket.
      • Flip the locking flap up on the touchscreen cable connector and remove the ribbon cable from the board.
      • Remove the screen from the device.
      Ask FixBot
    1. HP Elite x2 G4 Battery Replacement, Battery: step 4, image 1 of 1
      • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket on the motherboard.
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      Ask FixBot
    2. HP Elite x2 G4 Battery Replacement: step 5, image 1 of 1
      • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
      Ask FixBot
    3. HP Elite x2 G4 Battery Replacement: step 6, image 1 of 2 HP Elite x2 G4 Battery Replacement: step 6, image 2 of 2
      • Carefully lift the top edge of the battery off of the alignment pins.
      • Slide the bottom edge out from retention tabs on the display enclosure and remove the battery.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
George Homand
373 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 139
All Time: 327
