HP Elite x2 G4 Battery Replacement
  1. HP Elite x2 G4 Battery Replacement, Display Assembly: step 1, image 1 of 1
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Battery Replacement: step 2, image 1 of 1
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
    • You will hear an audible pop when the clips holding the screen are released. This is normal.
  3. HP Elite x2 G4 Battery Replacement: step 3, image 1 of 1
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
    • The ribbon cables are delicate. Take care to not pull on them when lifting the screen.
  4. HP Elite x2 G4 Battery Replacement: step 4, image 1 of 1
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Battery Replacement: step 5, image 1 of 1
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Battery Replacement, Battery: step 6, image 1 of 1
    • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
  7. HP Elite x2 G4 Battery Replacement: step 7, image 1 of 1
    • Carefully lift the top edge of the battery off of the alignment pins.
    • Remove the battery.
  8. HP Elite x2 G4 Battery Replacement: step 8, image 1 of 1
    • Slide the bottom edge out from retention tabs on the display enclosure and remove.
Goncalo Felix
325 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 42
Past 30 Days: 160
All Time: 3,995
