HP Elite x2 G1 1012 Display Replacement
    1. HP Elite x2 G1 1012 Display Replacement, Display: step 1, image 1 of 1
      • Be sure to power off and unplug your device before you begin your repair.
      • With the screen face down, lift up the stand as far as it goes.
      • Make sure not to force it past the resting point.
      Ask FixBot
    2. HP Elite x2 G1 1012 Display Replacement: step 2, image 1 of 2 HP Elite x2 G1 1012 Display Replacement: step 2, image 2 of 2
      • Use a T5 driver to remove the six screws on the back of the tablet.
      Ask FixBot
    3. HP Elite x2 G1 1012 Display Replacement: step 3, image 1 of 1
      • After removing the screws, delicately close the stand.
      • Flip the tablet on its back so that the screen is facing up.
      Ask FixBot
    4. HP Elite x2 G1 1012 Display Replacement: step 4, image 1 of 2 HP Elite x2 G1 1012 Display Replacement: step 4, image 2 of 2
      • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
      • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
      Ask FixBot
    5. HP Elite x2 G1 1012 Display Replacement: step 5, image 1 of 3 HP Elite x2 G1 1012 Display Replacement: step 5, image 2 of 3 HP Elite x2 G1 1012 Display Replacement: step 5, image 3 of 3
      • Remove the tape on the lower left side of the screen.
      • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
      Ask FixBot
    6. HP Elite x2 G1 1012 Display Replacement: step 6, image 1 of 2 HP Elite x2 G1 1012 Display Replacement: step 6, image 2 of 2
      • Disconnect the flex cable from the device using the spudger.
      • Remove the Display Assembly from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
4 other people completed this guide.
Colin Mika
973 Reputation
6 Guides authored
Cal Poly, Team S24-G7, Maness Spring 2018 Member of Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 66
All Time: 4,093
