HP Elite x2 1012 G2 Screen Replacement
    1. HP Elite x2 1012 G2 Screen Replacement, Screen: step 1, image 1 of 1
      • Make sure the device is turned off before starting.
      • Orient the device so the back is facing you, with the kickstand up.
      Ask FixBot
    2. HP Elite x2 1012 G2 Screen Replacement: step 2, image 1 of 3 HP Elite x2 1012 G2 Screen Replacement: step 2, image 2 of 3 HP Elite x2 1012 G2 Screen Replacement: step 2, image 3 of 3
      • Remove the six 3mm Torx T5 screws underneath the kickstand.
      Ask FixBot
    3. HP Elite x2 1012 G2 Screen Replacement: step 3, image 1 of 2 HP Elite x2 1012 G2 Screen Replacement: step 3, image 2 of 2
      • Turn the device over so the screen is facing you.
      • Place a suction cup firmly onto a corner of the screen.
      • Lift up gently until you see the screen separate from the casing.
      • Repeat this process for all four corners.
      • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
      Ask FixBot
    4. HP Elite x2 1012 G2 Screen Replacement: step 4, image 1 of 1
      • Lift the screen up and off of the device.
      • Pry each corner up first, otherwise you may damage or crack the screen.
      Ask FixBot
    5. HP Elite x2 1012 G2 Screen Replacement: step 5, image 1 of 3 HP Elite x2 1012 G2 Screen Replacement: step 5, image 2 of 3 HP Elite x2 1012 G2 Screen Replacement: step 5, image 3 of 3
      • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
      Ask FixBot
    6. HP Elite x2 1012 G2 Screen Replacement: step 6, image 1 of 2 HP Elite x2 1012 G2 Screen Replacement: step 6, image 2 of 2
      • Remove the screen by gently lifting it off of the device.
      Ask FixBot
6 other people completed this guide.
Noah Stapp
842 Reputation
2 Guides authored
Cal Poly, Team S18-G5, Livingston Spring 2018 Member of Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
4 Members
60 Guides authored
5 Guide Comments
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - Reply Share
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - Reply Share
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - Reply Share
The touch stopped working after the replacement. Any suggestions?
el._.msn - Reply Share
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 126
All Time: 11,901
