HP Elite X2 1013 G3 Screen Replacement
    1. HP Elite X2 1013 G3 Screen Replacement, Screen: step 1, image 1 of 1
      • Flip the device over so the base is facing the ceiling.
      • Lift up the tablet stand.
      • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
      Ask FixBot
    2. HP Elite X2 1013 G3 Screen Replacement: step 2, image 1 of 2 HP Elite X2 1013 G3 Screen Replacement: step 2, image 2 of 2
      • Flip the tablet over with the screen facing upwards.
      • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
      • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
      Ask FixBot
    3. HP Elite X2 1013 G3 Screen Replacement: step 3, image 1 of 2 HP Elite X2 1013 G3 Screen Replacement: step 3, image 2 of 2
      • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
      • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
      Ask FixBot
    4. HP Elite X2 1013 G3 Screen Replacement: step 4, image 1 of 2 HP Elite X2 1013 G3 Screen Replacement: step 4, image 2 of 2
      • Remove the screen from the tablet.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 73
All Time: 2,740
