HP ENVY 5530 Front Panel Replacement
    1. HP ENVY 5530 Front Panel Replacement, Front Panel: step 1, image 1 of 1
      • Lift up printer screen.
      Ask FixBot
    2. HP ENVY 5530 Front Panel Replacement: step 2, image 1 of 3 HP ENVY 5530 Front Panel Replacement: step 2, image 2 of 3 HP ENVY 5530 Front Panel Replacement: step 2, image 3 of 3
      • Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
      • Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
      Ask FixBot
    3. HP ENVY 5530 Front Panel Replacement: step 3, image 1 of 2 HP ENVY 5530 Front Panel Replacement: step 3, image 2 of 2
      • Remove the front panel by lifting each corner up.
      • Replace the front panel.
      Ask FixBot
Elizabeth Surface
1,477 Reputation
9 Guides authored
USF Tampa, Team 4-6, Meier Fall 2015 Member of USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
4 Members
108 Guides authored
4 Guide Comments
My HP Envy 5530 had a screw hidden beneath the label on the right side of the front panel. I used a knife to lift the label to access the screw.
rndymike - Reply Share
Is the front panel from a 5532 compatible with the Envy 5530?
Armando Pagan - Reply Share
Wish I would have seen the comment about the screw… fix your post… at least protect others from making the same mistake
Azpatch - Reply Share
Where does the cable go?
Victorian Lover - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 25
All Time: 2,755
