Up to 20% off select tools
HP Deskjet D1660 Power Button Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
86
All Time:
1,704
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Does the printer button not work or stay on when you are trying to turn the printer off? Use this guide to replace the malfunctioning button. This will ensure that you have a working printer that will actually print.
    1. HP Deskjet D1660 Power Button Replacement, Top Cover: step 1, image 1 of 1
      • Remove the back two 14.0 mm Torx #10 screws.
      Ask FixBot
    2. HP Deskjet D1660 Power Button Replacement: step 2, image 1 of 1
      • Lay the printer on its back.
      • Grab the paper tray by its right side and pull it to the left and up.
      Ask FixBot
    3. HP Deskjet D1660 Power Button Replacement: step 3, image 1 of 1
      • Open the frontal access panel by lifting it from the top.
      • Similar to the paper tray, grab it from the right side and pull it to the left and up.
      Ask FixBot
    4. HP Deskjet D1660 Power Button Replacement: step 4, image 1 of 3 HP Deskjet D1660 Power Button Replacement: step 4, image 2 of 3 HP Deskjet D1660 Power Button Replacement: step 4, image 3 of 3
      • Take out the two frontal 14.0 mm Torx #10 screws.
      • Carefully lift the frontal cover.
      • Don't lift it up aggressively. A strip will be attached to it.
      Ask FixBot
    1. HP Deskjet D1660 Power Button Replacement, Power Button: step 5, image 1 of 1
      • Remove the strip that connects the printer to the front cover.
      Ask FixBot
    2. HP Deskjet D1660 Power Button Replacement: step 6, image 1 of 2 HP Deskjet D1660 Power Button Replacement: step 6, image 2 of 2
      • Remove the two 13.0 mm Torx #10 screws.
      • Carefully lift it up. The button will be located under it.
      Ask FixBot
    3. HP Deskjet D1660 Power Button Replacement: step 7, image 1 of 1
      • Lift up the power button.
      Ask FixBot
Author
with
Justin Taiki Fukada
912 Reputation
7 Guides authored
Cal Poly, Team 1-41, Maness Winter 2014 Member of Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 86
All Time: 1,704
