HP Deskjet D1660 Encoder Strip Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
157
All Time:
5,782
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will replace the encoder strip, which the printer carriage uses to read its speed and position. It runs through the opening of the carriage and is attached to each end of the frame inside the printer. Without this strip, the carriage will slam against the side of the printer when it is turned on.
Tools
    1. HP Deskjet D1660 Encoder Strip Replacement, Encoder Strip: step 1, image 1 of 1
      • Remove the back two 14.0 mm Torx #10 screws.
      Ask FixBot
    2. HP Deskjet D1660 Encoder Strip Replacement: step 2, image 1 of 1
      • Lay the printer on its back.
      • Grab the paper tray by its right side and pull it to the left and up.
      Ask FixBot
    3. HP Deskjet D1660 Encoder Strip Replacement: step 3, image 1 of 1
      • Open the frontal access panel by lifting it from the top.
      • Similar to the paper tray, grab it from the right side and pull it to the left and up.
      Ask FixBot
    4. HP Deskjet D1660 Encoder Strip Replacement: step 4, image 1 of 3 HP Deskjet D1660 Encoder Strip Replacement: step 4, image 2 of 3 HP Deskjet D1660 Encoder Strip Replacement: step 4, image 3 of 3
      • Take out the two frontal 14.0 mm Torx #10 screws.
      • Carefully lift the frontal cover.
      • Don't lift it up aggressively. A strip will be attached to it.
      Ask FixBot
    5. HP Deskjet D1660 Encoder Strip Replacement: step 5, image 1 of 3 HP Deskjet D1660 Encoder Strip Replacement: step 5, image 2 of 3 HP Deskjet D1660 Encoder Strip Replacement: step 5, image 3 of 3
      • Looking at the printer from the front, carefully unhook the encoder strip from the left side.
      • Pull the strip to the left and push a little to unhook the strip.
      • Do the same thing on the other side by pulling to the right and pushing a little.
      • Pull the strip completely out from the cartridge holder.
      Ask FixBot
3 other people completed this guide.
Justin Taiki Fukada
912 Reputation
7 Guides authored
Cal Poly, Team 1-41, Maness Winter 2014 Member of Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 157
All Time: 5,782
