Up to 20% off select tools
HP Deskjet 6840 Maintenance
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
93
All Time:
1,599
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
In this guide, we're going to help you clean your HP Deskjet 6840 so that it keeps on printing the documents you need and the photos you love!
    1. HP Deskjet 6840 Maintenance, General Device: step 1, image 1 of 1
      • Start by turning the printer around so you can work on the backside of the printer.
      Ask FixBot
    2. HP Deskjet 6840 Maintenance: step 2, image 1 of 3 HP Deskjet 6840 Maintenance: step 2, image 2 of 3 HP Deskjet 6840 Maintenance: step 2, image 3 of 3
      • Use both hands to press the two grooves on the back of the printer. Simultaneously press both grooves down and in.
      • This will release the back panel from the printer.
      • Remove the back panel from the printer.
      Ask FixBot
    3. HP Deskjet 6840 Maintenance: step 3, image 1 of 3 HP Deskjet 6840 Maintenance: step 3, image 2 of 3 HP Deskjet 6840 Maintenance: step 3, image 3 of 3
      • Use a screwdriver to remove each visible screw.
      • Using two hands, pull out and remove the rear support structure.
      Ask FixBot
    4. HP Deskjet 6840 Maintenance: step 4, image 1 of 2 HP Deskjet 6840 Maintenance: step 4, image 2 of 2
      • Carefully remove the large, black shell that encases the internal body of your printer.
      • Gently remove the shell from the base of the printer by placing your hands at the corners and firmly lifting the shell until it pops off of the base. Do not pry or bend the shell.
      • Carefully detach wires that connect the shell to the printer's internal parts.
      Ask FixBot
    5. HP Deskjet 6840 Maintenance: step 5, image 1 of 3 HP Deskjet 6840 Maintenance: step 5, image 2 of 3 HP Deskjet 6840 Maintenance: step 5, image 3 of 3
      • Use a screwdriver to remove the screws from the printer carriage assembly and the green plastic motherboard.
      • Gently loosen the motherboard from its base, but do not fully remove it.
      Ask FixBot
    6. HP Deskjet 6840 Maintenance: step 6, image 1 of 3 HP Deskjet 6840 Maintenance: step 6, image 2 of 3 HP Deskjet 6840 Maintenance: step 6, image 3 of 3
      • Use a screwdriver to remove the screws securing the motor carriage.
      • If you need to replace the motor, remove the screws from the motor housing.
      • Carefully lift the motor out of the housing with your fingers and replace it with a new one.
      Ask FixBot
    7. HP Deskjet 6840 Maintenance: step 7, image 1 of 3 HP Deskjet 6840 Maintenance: step 7, image 2 of 3 HP Deskjet 6840 Maintenance: step 7, image 3 of 3
      • By now, your printer should resemble the one in the photograph.
      • Use the screwdriver to remove any remaining screws.
      Ask FixBot
    1. HP Deskjet 6840 Maintenance, HP Deskjet 6840 Maintenance: step 8, image 1 of 1
      • To clean the exterior of the device, generally a soft, moist cloth can be used to wipe away any dust, smudges, or other granules that may have collected on the device. Be careful not to dampen the cloth too much, as excessive water (or other liquids) slipping into the interior could damage the device.
      Ask FixBot
    2. HP Deskjet 6840 Maintenance: step 9, image 1 of 1
      • There may be an amount of ink residue that builds up inside the device, so be thorough when sterilizing your printer.
      • However, regarding general maintenance, the ink cartridges and carriage are your main concern, as most other residue is normal build-up for this device.
      • When cleaning your printer, do not use alcohol or other platen cleaners, as this could severely damage your device.
      Ask FixBot
    3. HP Deskjet 6840 Maintenance: step 10, image 1 of 1
      • To maintain the ink cartridges, you simply wipe them down with a soft, clean cloth.
      • However, if you find the dried ink stains disconcerting, know that they are character of a healthy, functioning device. You can still wipe them off, but be cautious not to rub too hard- you risk denting or otherwise damaging the machine.
      Ask FixBot
    4. HP Deskjet 6840 Maintenance: step 11, image 1 of 1
      • If you have further questions about extended care for your device, you may find this, this, and this to be helpful.
      Ask FixBot
Author
with
Magnolia
325 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 93
All Time: 1,599
