HP DV7-4285DX LCD Replacement
    1. HP DV7-4285DX LCD Replacement, Battery: step 1, image 1 of 1
      • Make sure laptop is shutdown and unplugged from power adapter.
      • Slide the battery release latch to the left and remove the battery.
      Ask FixBot
    2. HP DV7-4285DX LCD Replacement, Bottom Cover: step 2, image 1 of 3 HP DV7-4285DX LCD Replacement, Bottom Cover: step 2, image 2 of 3 HP DV7-4285DX LCD Replacement, Bottom Cover: step 2, image 3 of 3
      • Unscrew the five screws holding the bottom cover for accessing the RAM, hard drive and wifi card.
      • Five Phillips #1
      • When removing the cover, start from the top edge and lift up.
      • Remove cover.
      Ask FixBot
    3. HP DV7-4285DX LCD Replacement, Hard Drive: step 3, image 1 of 2 HP DV7-4285DX LCD Replacement, Hard Drive: step 3, image 2 of 2
      • Remove the four screws holding the hard drive.
      • Four Phillips #1
      Ask FixBot
    4. HP DV7-4285DX LCD Replacement, Hard Drive: step 4, image 1 of 2 HP DV7-4285DX LCD Replacement, Hard Drive: step 4, image 2 of 2
      • Unplug the SATA connection using the black pull tab.
      • Remove hard drive
      Ask FixBot
    5. HP DV7-4285DX LCD Replacement, RAM: step 5, image 1 of 1
      • Remove RAM by pushing the locking clips outwards.
      Ask FixBot
    6. HP DV7-4285DX LCD Replacement, Wireless Card: step 6, image 1 of 3 HP DV7-4285DX LCD Replacement, Wireless Card: step 6, image 2 of 3 HP DV7-4285DX LCD Replacement, Wireless Card: step 6, image 3 of 3
      • Use the edge of a plastic opening tool to pry the wifi antenna cable up from its socket on the wireless card.
      • Remove two screws from wireless card.
      • Two Phillips #1
      Ask FixBot
    7. HP DV7-4285DX LCD Replacement, Optical Drive: step 7, image 1 of 3 HP DV7-4285DX LCD Replacement, Optical Drive: step 7, image 2 of 3 HP DV7-4285DX LCD Replacement, Optical Drive: step 7, image 3 of 3
      • Remove the one screw holding the optical drive.
      • One Phillips #1
      • Use a spudger to push on the metal tab below where the screw was. This should disconnect the optical drive from the SATA connector.
      • Remove optical drive.
      Ask FixBot
    8. HP DV7-4285DX LCD Replacement: step 8, image 1 of 3 HP DV7-4285DX LCD Replacement: step 8, image 2 of 3 HP DV7-4285DX LCD Replacement: step 8, image 3 of 3
      • Remove the 26 screws on the bottom.
      • 20 Phillips #1
      • Three Phillips #0
      • Three Phillips #00
      Ask FixBot
    9. HP DV7-4285DX LCD Replacement, Keyboard: step 9, image 1 of 3 HP DV7-4285DX LCD Replacement, Keyboard: step 9, image 2 of 3 HP DV7-4285DX LCD Replacement, Keyboard: step 9, image 3 of 3
      • To the left of the battery connector is a keyboard release latch. Use a spudger to release the keyboard.
      • You may have to open the laptop some to keep the keyboard from re-latching.
      • Once freed, lift the keyboard up from the top.
      • Be careful not to damage or tear the ribbon cable.
      • Use the edge of a plastic opening tool to carefully flip up the retaining flap on the keyboard ZIF socket.
      • Remove keyboard.
      Ask FixBot
    10. HP DV7-4285DX LCD Replacement: step 10, image 1 of 3 HP DV7-4285DX LCD Replacement: step 10, image 2 of 3 HP DV7-4285DX LCD Replacement: step 10, image 3 of 3
      • Remove the two screws.
      • Two Phillips #1
      • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the three ZIF sockets.
      Ask FixBot
    11. HP DV7-4285DX LCD Replacement: step 11, image 1 of 3 HP DV7-4285DX LCD Replacement: step 11, image 2 of 3 HP DV7-4285DX LCD Replacement: step 11, image 3 of 3
      • Starting on the left side, use a spudger to pry the cover up. Work your way around to the right side.
      • Remove cover.
      Ask FixBot
    12. HP DV7-4285DX LCD Replacement: step 12, image 1 of 2 HP DV7-4285DX LCD Replacement: step 12, image 2 of 2
      • Remove the screw on the left side holding the lid hinge.
      • One Phillips #1
      • Use the black pull tab to remove the LCD connector.
      Ask FixBot
    13. HP DV7-4285DX LCD Replacement: step 13, image 1 of 3 HP DV7-4285DX LCD Replacement: step 13, image 2 of 3 HP DV7-4285DX LCD Replacement: step 13, image 3 of 3
      • Remove the screw on the right side holding the lid hinge.
      • One Phillips #1
      • Use a spudger to disconnect the speaker wire.
      • Carefully pull the wifi antenna wires out from the bottom case.
      • Remove lid.
      Ask FixBot
    14. HP DV7-4285DX LCD Replacement: step 14, image 1 of 3 HP DV7-4285DX LCD Replacement: step 14, image 2 of 3 HP DV7-4285DX LCD Replacement: step 14, image 3 of 3
      • Using a metal spudger remove the two hinge covers.
      • Use a metal spudger to remove the two screw covers.
      Ask FixBot
    15. HP DV7-4285DX LCD Replacement: step 15, image 1 of 3 HP DV7-4285DX LCD Replacement: step 15, image 2 of 3 HP DV7-4285DX LCD Replacement: step 15, image 3 of 3
      • Remove the two Phillips #1 screws that were under the covers.
      • Starting on the left side, use a spudger to pry the bezel up.
      • Work your way around and remove the bezel.
      Ask FixBot
    16. HP DV7-4285DX LCD Replacement: step 16, image 1 of 3 HP DV7-4285DX LCD Replacement: step 16, image 2 of 3 HP DV7-4285DX LCD Replacement: step 16, image 3 of 3
      • Remove the eight screws holding the LCD panel.
      • Eight Phillips #1
      • Use a spudger to disconnect the webcam connector.
      • Lift up the LCD panel.
      • The webcam wire is attached to the back of the panel. Carefully peel it off the panel.
      Ask FixBot
    17. HP DV7-4285DX LCD Replacement: step 17, image 1 of 1
      • Use a sudger to disconnect the wire from the LCD panel.
      • Remove LCD panel.
      Ask FixBot
    18. HP DV7-4285DX LCD Replacement: step 18, image 1 of 3 HP DV7-4285DX LCD Replacement: step 18, image 2 of 3 HP DV7-4285DX LCD Replacement: step 18, image 3 of 3
      • Remove the four screws (two on each side) holding the hinges on the sides.
      • Four Phillips #1 (two on each side)
      • Remove the hinges.
      Ask FixBot
    19. HP DV7-4285DX LCD Replacement: step 19, image 1 of 1
      • LCD remains.
      • To reassemble, follow these instructions in reverse order.
      Ask FixBot
13 other people completed this guide.
Patrick
531 Reputation
1 Guide authored
1 Guide Comment
good thank :)
Ernesto Sanabria Gonzalez - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 8,650
