HP Compaq nc6400 Optical Drive Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
11
Past 30 Days:
90
All Time:
5,258
Comments: 3
3 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will take you through the process of replacing the optical drive in a HP Compaq nc6400 Laptop. You will need the correct replacement optical drive for your laptop to complete the installation.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. HP Compaq nc6400 Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Turn off and unplug laptop.
      Ask FixBot
    2. HP Compaq nc6400 Optical Drive Replacement: step 2, image 1 of 1
      • Locate the battery lock below the battery labeled one.
      • Slide the lock all the way to the left to release the left lock of the battery.
      Ask FixBot
    3. HP Compaq nc6400 Optical Drive Replacement: step 3, image 1 of 1
      • Locate the lock labeled two at the bottom right corner below the battery.
      • Slide and hold the lock to the left.
      Ask FixBot
    4. HP Compaq nc6400 Optical Drive Replacement: step 4, image 1 of 1
      • Once both the battery locks are unlocked, slide the battery out to remove.
      Ask FixBot
    1. HP Compaq nc6400 Optical Drive Replacement, Optical Drive: step 5, image 1 of 2 HP Compaq nc6400 Optical Drive Replacement, Optical Drive: step 5, image 2 of 2
      • Remove the 4 mm P0 Phillips-head screw indicated by the icon of a lock and disk.
      Ask FixBot
    2. HP Compaq nc6400 Optical Drive Replacement: step 6, image 1 of 2 HP Compaq nc6400 Optical Drive Replacement: step 6, image 2 of 2
      • Press and release the eject icon to partially eject the optical drive.
      • Use of a spudger may be necessary to pry open the optical drive.
      Ask FixBot
    3. HP Compaq nc6400 Optical Drive Replacement: step 7, image 1 of 1
      • Grasp the sides and pull the optical drive out.
      Ask FixBot
2 other people completed this guide.
Chad Williams
252 Reputation
1 Guide authored
Cal Poly, Team 14-6, Forte Fall 2013 Member of Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 90
All Time: 5,258
