HP Compaq Presario V6000 Trackpad Replacement
  1. HP Compaq Presario V6000 Trackpad Replacement, Trackpad: step 1, image 1 of 1
    • Use the metal spudger to gently remove the plastic plate from the rest of the top panel.
    • Be careful not to break the plastic tabs connecting the two top panels.
    Ask FixBot
  2. HP Compaq Presario V6000 Trackpad Replacement: step 2, image 1 of 1
    • Separate the connection of the top piece from the board.
    Ask FixBot
  3. HP Compaq Presario V6000 Trackpad Replacement: step 3, image 1 of 1
    • Remove the connection from the keyboard to its housing.
    Ask FixBot
  4. HP Compaq Presario V6000 Trackpad Replacement: step 4, image 1 of 1
    • Separate the power connections.
    Ask FixBot
  5. HP Compaq Presario V6000 Trackpad Replacement: step 5, image 1 of 1
    • Unravel the wire.
    Ask FixBot
  6. HP Compaq Presario V6000 Trackpad Replacement: step 6, image 1 of 1
    • Remove the screws connecting the plastic housing to the screen.
    • Use caution when removing the last screen. Do no damage the screen.
    Ask FixBot
  7. HP Compaq Presario V6000 Trackpad Replacement: step 7, image 1 of 1
    • Make sure to grip the screen tightly and separate the top and bottom.
    Ask FixBot
  8. HP Compaq Presario V6000 Trackpad Replacement: step 8, image 1 of 2 HP Compaq Presario V6000 Trackpad Replacement: step 8, image 2 of 2
    • Remove the screws that hold the track pad in place.
    • Remove the track pad.
    Ask FixBot
adam
323 Reputation
2 Guides authored
Texas Tech, Team 38-4, Bennett Fall 2016 Member of Texas Tech, Team 38-4, Bennett Fall 2016
TTU-BENNETT-F16S38G4
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 22
All Time: 862
