HP Compaq Presario V3000 RAM Replacement
    1. HP Compaq Presario V3000 RAM Replacement, RAM: step 1, image 1 of 2 HP Compaq Presario V3000 RAM Replacement, RAM: step 1, image 2 of 2
      • Locate the two screws holding the RAM cover in place
      • Use Phillips #0 screwdriver to remove the two 4.5mm Philips head screws
      • Place screws on magnetic mat to help avoid losing the screws
      • Lift the RAM cover towards the battery eject latch
      Ask FixBot
    2. HP Compaq Presario V3000 RAM Replacement: step 2, image 1 of 3 HP Compaq Presario V3000 RAM Replacement: step 2, image 2 of 3 HP Compaq Presario V3000 RAM Replacement: step 2, image 3 of 3
      • Lift foil covering RAM retention clips
      • Only pull the foil until the retention clips are visible. Do NOT continue pulling after.
      • Retention clips should be on the sides of the RAM chip
      Ask FixBot
    3. HP Compaq Presario V3000 RAM Replacement: step 3, image 1 of 3 HP Compaq Presario V3000 RAM Replacement: step 3, image 2 of 3 HP Compaq Presario V3000 RAM Replacement: step 3, image 3 of 3
      • Push retention clip on each side of RAM OUTWARDS
      • RAM will pop up
      Ask FixBot
    4. HP Compaq Presario V3000 RAM Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, carefully pull the RAM chip away from the RAM slot
      Ask FixBot
    5. HP Compaq Presario V3000 RAM Replacement: step 5, image 1 of 3 HP Compaq Presario V3000 RAM Replacement: step 5, image 2 of 3 HP Compaq Presario V3000 RAM Replacement: step 5, image 3 of 3
      • Push retention clip on each side of the second RAM chip OUTWARDS
      • RAM chip will pop up
      Ask FixBot
    6. HP Compaq Presario V3000 RAM Replacement: step 6, image 1 of 1
      • Repeat Step 5 and use tweezers to carefully pull RAM away from RAM slot
      Ask FixBot
2 other people completed this guide.
Bernard Lee
143 Reputation
1 Guide authored
IUPUI, Team S1-G1, Harley Spring 2017 Member of IUPUI, Team S1-G1, Harley Spring 2017
IUPUI-HARLEY-S17S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 3,871
