HP Compaq Presario V3000 Keyboard Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
71
All Time:
2,322
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide demonstrates how to take out the keyboard from your laptop and replace it with a new one.
Tools
    1. HP Compaq Presario V3000 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
      • The battery may be warm or even HOT to the touch.
      • Locate the battery EJECT latch.
      Ask FixBot
    2. HP Compaq Presario V3000 Keyboard Replacement: step 2, image 1 of 2 HP Compaq Presario V3000 Keyboard Replacement: step 2, image 2 of 2
      • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
      • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
      • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
      Ask FixBot
    3. HP Compaq Presario V3000 Keyboard Replacement: step 3, image 1 of 2 HP Compaq Presario V3000 Keyboard Replacement: step 3, image 2 of 2
      • Pull the battery up and towards you to remove it from the laptop chassis.
      • Once the battery is out, you will be able to check the battery label for the replacement part number.
      • The part number is needed when purchasing a new battery.
      Ask FixBot
    1. HP Compaq Presario V3000 Keyboard Replacement, Keyboard: step 4, image 1 of 3 HP Compaq Presario V3000 Keyboard Replacement, Keyboard: step 4, image 2 of 3 HP Compaq Presario V3000 Keyboard Replacement, Keyboard: step 4, image 3 of 3
      • Use a Phillip's #00 screwdriver to remove all of the circled screws. Apply moderate pressure to each screw to avoid stripping it.
      • The three screws circled in red are 9mm Phillip's #00 screws.
      • The three screws circle in orange are 5mm Phillip's #00 screws.
      • The three screws circled in yellow are 6mm Phillip's #00 screws.
      Ask FixBot
    2. HP Compaq Presario V3000 Keyboard Replacement: step 5, image 1 of 2 HP Compaq Presario V3000 Keyboard Replacement: step 5, image 2 of 2
      • Insert the rubber spudger gently below the edge of the keyboard.
      • Lift the keyboard vertically to detach it from the top assembly.
      Ask FixBot
    3. HP Compaq Presario V3000 Keyboard Replacement: step 6, image 1 of 1
      • Flip the keyboard over. It may be easiest to hold it up in order to detach its wire assembly.
      Ask FixBot
    4. HP Compaq Presario V3000 Keyboard Replacement: step 7, image 1 of 2 HP Compaq Presario V3000 Keyboard Replacement: step 7, image 2 of 2
      • Use your plastic spudger to unlock the two white sliding connectors located on the left and right side of the device by gently pushing them out.
      Ask FixBot
    5. HP Compaq Presario V3000 Keyboard Replacement: step 8, image 1 of 1
      • With the white sliding connectors unlocked, gently grab the connector power cable and pull it out.
      • It should come out very easily; do not force it.
      Ask FixBot
3 other people completed this guide.
McKenzie Coleman
137 Reputation
1 Guide authored
IUPUI, Team S1-G1, Harley Spring 2017 Member of IUPUI, Team S1-G1, Harley Spring 2017
IUPUI-HARLEY-S17S1G1
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 71
All Time: 2,322
