Up to 20% off select tools
HP Compaq NC6120 RAM Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
10
Past 7 Days:
31
Past 30 Days:
95
All Time:
2,463
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
Replacing the RAM to an HP Compaq NC6120 is an effective way to maximize the computer's running speed. It's a simple replacement, as HP made the compartment easily accessible and user-friendly. If the computer is running slowly, and you know that no parts are broken, replacing the RAM is one of the first steps that should be done to make your computer run faster.
    1. HP Compaq NC6120 RAM Replacement, RAM: step 1, image 1 of 1
      • Locate the plastic casing covering the RAM chip.
      • The plastic casing is found on the back side of the laptop, in the middle of the base panel.
      Ask FixBot
    2. HP Compaq NC6120 RAM Replacement: step 2, image 1 of 2 HP Compaq NC6120 RAM Replacement: step 2, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the M2 screw securing the plastic casing covering the RAM chip.
      • Now remove the plastic casing and you should see the RAM chip.
      Ask FixBot
    3. HP Compaq NC6120 RAM Replacement: step 3, image 1 of 3 HP Compaq NC6120 RAM Replacement: step 3, image 2 of 3 HP Compaq NC6120 RAM Replacement: step 3, image 3 of 3
      • Remove the RAM chip from underneath the casing.
      • It should easily pop out.
      Ask FixBot
    4. HP Compaq NC6120 RAM Replacement: step 4, image 1 of 1
      • Replace the RAM chip with a new RAM chip.
      Ask FixBot
3 other people completed this guide.
Author
with
Keenan
494 Reputation
2 Guides authored
Cal Poly, Team 17-4, Forte Spring 2015 Member of Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 31
Past 30 Days: 95
All Time: 2,463
