HP Compaq NC6120 Cooling Fan Replacement
  1. HP Compaq NC6120 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 3 HP Compaq NC6120 Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 3 HP Compaq NC6120 Cooling Fan Replacement, Cooling Fan: step 1, image 3 of 3
    • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
    • Place the cable off to the side so that it is out of the way.
    Ask FixBot
  2. HP Compaq NC6120 Cooling Fan Replacement: step 2, image 1 of 2 HP Compaq NC6120 Cooling Fan Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two 7.0 mm screws on the top left and top right corners of the cooling fan.
    Ask FixBot
  3. HP Compaq NC6120 Cooling Fan Replacement: step 3, image 1 of 2 HP Compaq NC6120 Cooling Fan Replacement: step 3, image 2 of 2
    • Remove the fan from the laptop.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Mateo Cuellar
601 Reputation
4 Guides authored
Cal Poly, Team 17-4, Forte Spring 2015 Member of Cal Poly, Team 17-4, Forte Spring 2015
CPSU-FORTE-S15S17G4
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 46
All Time: 959
