Up to 20% off select tools
HP Compaq C700 RAM Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
99
All Time:
1,690
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will teach how to remove the necessary components to gain access to and remove/replace the RAM module(s).
    1. HP Compaq C700 RAM Replacement, RAM: step 1, image 1 of 1
      • It is recommended that the computer be powered off while working to avoid risk of electrocution.
      • Turn off the computer by pressing and hold the power button located above the keyboard.
      Ask FixBot
    2. HP Compaq C700 RAM Replacement: step 2, image 1 of 1
      • Locate two phillips head 3 mm length screws on the hatch.
      • Using the PH0 screwdriver, remove the screws.
      Ask FixBot
    3. HP Compaq C700 RAM Replacement: step 3, image 1 of 1
      • Lift up the hatch.
      Ask FixBot
    4. HP Compaq C700 RAM Replacement: step 4, image 1 of 1
      • Using the plastic opening tool, open the locks by inserting the tool on the side of the beige locks to release the RAM.
      Ask FixBot
    5. HP Compaq C700 RAM Replacement: step 5, image 1 of 1
      • Gently pull out the RAM.
      Ask FixBot
4 other people completed this guide.
Author
with
Khang Nguyen
173 Reputation
1 Guide authored
UMass Dartmouth, Team 5-6, Martin Fall 2016 Member of UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 99
All Time: 1,690
